Cell Phones Logo
Anonymous Posted on Jul 17, 2009
I got to find the code to unlock my phone lg u990c
I would like some one to please help me get the code to unlock my lg u990c from 3g to any other sim card
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jul 17, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
23386
Points
14
You can go to a store they can do it for you or you can buy a TurboSim http://www.turbosim.net/
My lg 4g lte does not support indian sim card becoz of country lock.please give me a solution.my cell phone is lg verizon(model no.-vs840 4g)
If you bought a verizon phone, it is locked on the provider. They should make it sim lock free when the contract is over. For that they should give you a code and directions how to use the code. Then still you could be in trouble, because not all providers use the same transmitter systems. They all call it 3G or 4G, but the systems differ in details, making it in a lot of cases impossible to use an unlocked phone on another cell system.
So first ask the unlock code then check if it works on an other SIM.
You need the vermin sim to unlock the phone in the first place.
There are web sites who offer unlock codes, but you have to pay for that and it not always is successful.
Unlock codes for Tracfone LG800g
ineed softwear driver mobil lg u990c
1helpful
2answers
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
2answers
Invalid usim card
unlock phones are so unperdictable...there may not be a fix for this issue..other then getting an AT&T phone....and even if u are able to get it to start working again more then likely u wil continue to have many more isses..mainly becuz of the network changes..for example....using 3g and 3g only...last year the AT&T network was stil using both 2 and 3g network and there was even a few 2g SIM cards being sold in stores...now it almost all 3g..which of course complicates many things...even if u own a 2g AT&T phone a 3g SIM card can be and will be used on that phone....with unlock phones running on the 2g network the issues with not having a SIM card where possible...it was still unstable when wanting to use data services....but voice services were possible...now with everything going 3g...its makes things alot more complicated with AT&T if using a phone without SIM cards...if ur phone has the fuction to beable to shut off 3g networking and run on 2g.(like the apple iphone has) then try that....good luck
Lg kf700 wont accept any sim cards,
it sounds weird that it worked before with same sim card. Generally USIM locked message means phone is locked to network and you need to unlock it with network unlock code to remove USIM locked and use phone on different network.
gsmwong
2answers
Need to Unlock LG SHINE CU720 from ATT
fastunlocking.blogspot.com try this service, very fast and trust.
I can't unlock my LG 3G phone, please help me.
if the SIM is secured properyl (not backward or anything) then there must be a hardware problem and you will need to get LG to repair it
1helpful
3answers
I need unlocking lg u890
i had a lg u890 mobile phone that i got unlocked but it had the same proble where i swithched on my phone it used to ask for the usim code..my old phone was locked to the 3 nt/wrk i got it unlocked so i could use my 3 nt/wrk sim card or any network simcard but i used vodafone 3g sim card.the code i used with my vodafone 3g network simcard in phone when switched phone on & it asked for usim sim code i inserted code i got & it shut the phone down then on again then it wld work with vodafone no bother at all it even came up with vodafone uk etc.but i had to reconfigure the sms/text telephone number aswell as reconfigure the mms settings & numbers etc aswell as reconfigure wap settings from 3g network to vodaphones.but after i got it all unlocked & settings changed etc & inserted a different 3g network simcard ie vodaphone/orange/o2/3g sim/t-mobile/tesco sim/virgin sims & switched phone on it asked for usim code i tryed the code i have & inserted the same code i have it/they switched phone off & then back on & all network usim card worked with no problems at all.the code i have is.>>> 142358#*# thats 142358# * # all 1 item/action.once you insert that 142358#*# thats it your phone will shut down then restart up & go onto the network usim card you want to use or inserted before using code.but 1 thing tho please remember if u switch off your phone or your phone switches off as batterys run out no power u will need to insert the code again.& another thing code wont work if your phone switches off or you switch it off & plug your mobile battery charger into phone to charge your battery up on the phone & you switch you phone back on when you are charging your phone as the phone will switch on & say insert usim code if you enter the code the phone will switch off & back on again but it will still request usim code.so you will have to wait unto there is plenty of charge in the battery to take phone off charge & swithch your phone on get the usim code message insert code above phone will switch off & straight back on again & then it will go onto your prefured usim card then you can plug your charger into phone again to charge phone up.you can use your phone on charger when u have entered usim code & it switched off & on again & registered with the prefered network.i hope this is of use to you as it is to me.if you try this code & either if it works or not please can you let me knows ty.email [email protected]
2answers
4answers
LG KU250 unlocking
No, for now no unlock solution!!!
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
