It's my friends car he was changing spark plugs and one broke went down the cylinder and he thought he could start it to retrieve it. messed up the head broke a valve and messed up the piston I already have the head off.
Remove the oil pan and unbolt the connecting rod from the crankshaft on the damaged piston and push it up. It will come out without removing the engine
You do not mention the model of car, but if you have room you can drop the pan and undo the connecting rod for the cylinder that is damaged. Remove the piston from the top. Check the cylinder walls for damage. Light scratches can be honed. Do not reuse the piston rings as they may be damaged also. Good luck.
Testimonial: "Thank you that was very helpful and it's a 2000 honda crv"
