Your oil light is not a lvl indicator, it is a pressure indicator. If it is coming on you need to verify what your pressure actually is. Get a mechanical gauge hooked to the engine, you should have above 25psi. If not then you will need to go into the engine and figure out if you have a plugged sump tube, bad oil pump, or too much bearing clearance causing your low pressure condition.
