The strip was not used in machines manufactured after a certain date. You can carefully remove it with no problem. Try CCS Business Machine in Wayne, MI 734 727 4779
The first time you use the machine you need to make sure it is full of water - before you plug it in and turn it on. Put an empty coffee pot under the brew basket and fill another empty pot with clean cold water.
Pour the water into the coffee maker. If water comes out then you can plug it in and turn it on. The water heating tank holds about 2-1/2 pots of water so if your machine is empty you will need to keep adding water before you turn it on otherwise you may burn up the heating element.
After the green light comes on - indicating that the tank is hot you can brew a pot of coffee. This machine is meant to be left on all of the time so it is always ready to brew. If you choose to turn it off when not in use, you will need to give it about 10 minutes to fully heat up the water before you brew.
I just repaired my Bloomfield 8543 unit. I removed the top, by first removing the top rear 2 screws and unplugging the 2 heating element wires under it. Then mark all the wires that go to everything, (it is only a few) remove the center screw that holds the water tank lid brace down, slid the brace to one side (the groove on one side is longer) and remove the brace. (My brace was bent.) Then lift the lid (the heating elements will come with it) and clean the gasket. I went as far as to remove the tank, clean that as well as all the tubes. I tightened everything down and it worked perfectly again. Good luck, ken
