Baby Gear Logo
Posted on Jul 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Test test 1507 - Back to Basics Baby Gear
Ekse
Level 3:
  • Master 13,435 Answers
  • Posted on Jul 15, 2009
Ekse
Master
Level 3:
Answers
13435
Questions
82
Helped
3985280
Points
38023
Test Test, the date is 15.07.2009, The time is 15:06 or 3:06 pm In finland.
Weather outside is fantastic.
No problems to report with website. All seems to be working OK, aside from few reports of Not approved experts answering chat sessions with expert utility.
Thank you, keep on.
Bye
Need operator manual for Taylor weather radio 1507
The manual for the 1507 is available from Taylor. The direct link is http://www.taylorusa.com/media/IBs/1507_ib.pdf .
I hope this helps.
2helpful
Model 1507. I can follow the upper thread instructions as far as 5 in the manual but no further as I don't appear to have a 'slotted eye, of the take up lever.
Rotate the hand wheel towards you on the furthest right of your Singer 1507 machine . This should take the lever up and you should be able to thread it then.
Dec 11, 2010 • Singer 1507
The left channel on my denon avr-1507 no longer works. The speaker tests out fine. Is there a fuse that can be swapped for this or some other easy fix?
there are no speakers fuses on this model it only shows relays so your probable couse is your left channel went bad specially if you like to play it loud and for long periods of time ( I recomend that you have it repaired by a profesional ) good lock ,, I have the service manual in case you need it
1helpful
2answers
5helpful
Manual for singer 1507
I scanned my manual and uploaded it to a file sharing site here is the link to the file:
www.4shared.com/file/133426020/8af58505/Singer_1507_manual.html
I only scanned in the English pages, I hope that is not a problem.
Mar 20, 2009 • Singer 1507
Denon AVR-1507 No sound on left front channel
Because the sound is only faint says to me that the power amp that controls the left channel is faulty. You need to look at the device(s) on the heatsink and probably replace them.
Alpine MRV-1507 "low Voltage"
If it indicates that you have an open shield ground, read through the following page. It will show you how to test the shield ground connection of your head unit..
Temporary RCA Shield Repair
1helpful
MRV - 1507 Question ...
The MRV-1507 is a two channel amplifier, below I've pasted important info from the manual:
Battery Lead (Sold Separately)
Be sure to add a 80 amp fuse as close as possible
to the battery’s positive (+) terminal. This fuse will
protect your vehicle’s electrical system in case of a
short circuit. If you need to extend this lead, the wire
gauge should be AWG8 or larger.
MRV-1507 ... 80A amp fuse
Power Output: RMS Continuous Power (at 12.0V, 20 Hz to 20
kHz)
MRV-1507
Per channel into 4 ohms ......................... 150W, 0.08% THD
Per channel into 2 ohms .......................... 300W, 0.3% THD
Bridged into 4 ohms ................................ 600W, 0.3% THD
You can find a manual for this amp here:
http://www.alpine-usa.com/US-en/support/support_search.php?modelname=mrv-1507
Top Back to Basics Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Back to Basics Baby Gear Expert? Answer questions, earn points and help others
