Computers & Internet Logo
Posted on Jul 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Email doesn't display full screen. margins are too narrow
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Jul 16, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557715
Points
31058
Click anywhere inside the E-mail window.
Hold down the ALT key.
Press/release the "space-bar".
Type one 'x' to "maximize" the E-mail window.
Auto Config Please Wait keeps popping up why?
Not enough information to answer with any sense of accuracy, so let's just take a stab in the dark that is it a computer you are asking about and not a tire balancer or a smart fridge :>D
How to fix "Auto Config Please Wait" Error ' Techwalla
https://www.techwalla.com > Tech Support > How To
The "Auto Config Please Wait" error occurs when there is a problem transmitting images from your computer tower to your computer monitor.
People also ask
How do I fix auto config please wait?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;">
How do I turn off auto adjust on my monitor?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;">
What does processing auto configuration mean?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;">
Feedback Web results
How To Disable "Auto Config Please Wait"? - Acer Community
https://community.acer.com > Software > Windows 10
Nov. 15, 2020 · 2 posts · 1 author
The "Auto Config Please Wait" error tends to pop up when full screen games are being played. To get around this error, change the settings of ...
https://answers.microsoft.com/en-us/windows/forum/...
https://answers.microsoft.com > windows > forum > all
How To Disable Auto Config Please Wait? - Windows 10 Forums
https://www.windowsphoneinfo.com > threads > how-to...
Nov. 11, 2020 - The "Auto Config Please Wait" error tends to pop up when full screen games are being played. To get around this error, change the settings of ...
4 posts · Hello! I am constantly getting a box popping up saying auto config please wait, how do I s
2answers
How do I increase the area where I type?
You should have a "margin " adjustment on the typewriter. Just narrow the current margin
Pt 65 margins
Opening Your Document
Open your Microsoft Word document by double-clicking the Word icon on your desktop. If you do not see the icon on your desktop, then you can locate it where it is buried on your "Start" menu. Click "Start," followed by "All Programs." Then click "Microsoft Office," followed by "Microsoft Office Word." A new document will open on your screen. Click the "Office Button," followed by "Open." Scroll through the files listed, and double-click the one you would like to print. It will open on your screen.
Check Your Margins
By default, your page margins are set to 1-inch margins on the top, bottom, right and left of your page. You can check your margins or change them by clicking "Page Layout," followed by the "Margins" button.
Select New Margins
Select a different margin size, such as "Narrow," which indicate 1/2-inch margins, or "Wide," which indicate one-inch margins on the top and bottom and two-inch margins on the left and right. You also can select "Moderate," which indicate one-inch margins on the top and bottom and 3/4-inch margins on the left and right. Finally, you can select "Mirrored," which indicates one-inch margins for the top, bottom and outside. The inside margins are set at 1 1/4 inches.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Brother Printer Support
Paper too narrow only receive fax
possible that the margins you are using are incorrectly set
I have a toshiba 40 inch flat tv. I cannot make it full screen. It is as if it has black margin around the picture making it appear like a 32 inch tv. What do I do?
If this is reffering to having a pc/laptop plugged into the screen, try starting the computer with the tv already plugged in and on the correct channel. If this doesn't cure your problem then try setting the screen resolution in your display properties. set to 1920x1080 or 1280x720, this should cure your problem, if this is not a computer related issue, have a look in the display settings for your tv and see if there is a resize option or similar to adjust the image size.
Hope that this helps.
2answers
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Cannot print avery labels, get message the margins of section 1 are set outside the printable page, or will run thru printer , printing complete get blank page
I assume this error is occuring in Microsoft Word.
  1. Create a new document, with a full page of the label you are having trouble printing.
  2. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
  3. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
  4. Click the Fix button to have Word change the margins
    to match your printer. You should now see the Margins dialog with the new margin settings.
  5. Click OK.
One thing to watch for- on some inkjet printers, the printable area is narrower than the labels. This will cause the labels to shift to the right on the page and be misaligned when you print.
If the labels run off the right edge of the page display, or are misaligned when you print, an extra procedure is needed.
  1. Undo ([Ctrl]+[Z]) the new margin setting, or create a new page from the label template again.
  2. Select the entire table of labels ([Ctrl]+[A]).
  3. Right-click the table, and select Table Properties.
  4. Click the Text wrapping "Around" option, then the Positioning button.
  5. Change the Horizontal position to Center, Relative to Page.
    Uncheck the "Move with text" option. Click OK to the Table Positioning dialog, then click OK to the Table Properties dialog.
  6. Left-click (or press an arrow key) to "deselect" the table, then go into the margins dialog (see above) and allow Word to fix the margin settings again.
With the labels aligned to the page, rather than the margins, the new margin settings should not cause the labels to shift.
Once you have the margins set correctly for your printer, I would save the empty page of labels to use as a "template".
1helpful
Margin problem
Problem---Printer prints email on the very edge of the paper and leaves off the first 3 letters of every word down the edge of that margin. If you have Windows Live Mail forget trying to fix it from there. Clicking File will not give you the page setup option you are looking for. Go to the bottom of the screen, click "all programs", look for and click "Internet Explorer", click File, click "page setup". A screen comes up in which you can change the margins. The left margin is probably set on .25. Change it to .75. Okay. Go back and run a test email.
Grand Canyon Tech
Grand Canyon Tech
