There are 2 belts. One goes around the Crankshaft. the Power Steering Pump and the Air Conditioner Compressor (if equipped) and the other belt goes around the Crankshaft, The Alternator and the Water Pump. You can have your local parts supplier verify that you have the correct belt for the vehicle by calling them and giving them the number on the belt. Also make sure that you are installing the belt in the correct position. i.e. putting the alternator belt on the alternator and not on the power steering, etc.
could have been a loose belt to start with. check alt and water pump. if alt is not noisey and charging. check water pump for leaks and noise. make shore belt is in good condision and the correct tension
The water pump is driven by the timing belt, which is on the passenger side of your engine. You would need to remvoe all belts, and then the timing belt cover, and the timing belt to change your water pump.
A 626 has two belts. One drives the power steering and water pump (rear belt in 6 cyl) and other front belt drives the a/c and alternator. On the 4 cyl, the front belt drives the power steering and the a/c, and the rear belt drives the water pump and the alternator. All of these are easy to change.
Try turning the wheel when standing still with the engine running.
If it is tight check the obviouse, has the power steering belt come off. If not check if there is fluid in the steering pump resavour. If the belt is on and you have fluid you may have a bad pump.
I hope this helps
Regards
Sam
replacement of timing belt $350-$500. aftermarket shops will try to sell you a package containg a belt, water pump, and tensioner pulley. the dealer will just replace the belt, they might recommend to replace the water pump if there are alot of miles on the car, they will also inspect the pulley for wear.
