Wharfedale PowerCube PC-10 Subwoofer
Problem for Wharfedale PowerCube PC-10 Subwoofer
Wharfedale 10inch cude subwoofer that has a feedback hum when con
By vandergoot on Jul 14, 2009
I have a Yamaha amp and all the speakers work fine. Added the above speaker. No hum whem only connected to the power supply but as soon as it is connected to the amp a low hum starts. Speaker appears to work fine but the hum is apin. Anu advice would be great.
Comments:
Jul 16, 2009
- Thanks Ganx. I have tried different leads Checked the fuses etc but the hum is still there. I dont want to disconnect the earth lead. It only hums when it is connected to the amp. Have also tried it on a friends amp does the same thing on his. The amp is a Yamaha.
Best Solution
posted on Jul 14, 2009
Very Helpful)
Ganx
Rank: Guru
Rating: 91%, 48 votes
Hiya, try a different input cable (from amp to sub) if you have make sure that is ok.
Failing that if there is an earth in the plug, try to disconnect that (earth loop) - unlikely but hey electronics.... anything possible :)
If still there with new cable, earth off etc, then the Yamaha could have a problem but find that difficult to swallow...
Let me know if helps, see any other possibilty
Best of luck
Comments:
Jul 26, 2009
- Hi vandergoot,
It really does sound like an earth loop issue, especially if its doing the same on another amp.
If you not happy about disconnecting the earth, the try leaving the earth free on the input cable. Test it by putting a pin/clip or something to the centre ring of the input and only touching the tip of the rca plug. That way the earth is off. If it sounds much better, then it is an earth problem, you may not have a choice but to disconnect the main earth from plug
The other possibility is that the earth on the sub is not connected correctly. Try earthing the outside ring of the RCA while its all plugged in to any metal screw etc just with a short piece of wire.
Not ideal ways either way but might get lucky. If it doesnt help, will have to go in. Probably not to serious (broken track/loop) so should be fine but get a quote first!
Best of luck
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
triloksiva12
Rank: Master
Rating: 74%, 8 votes
what type of amp is it
Was this helpful?
Yes
No
Popular Solutions for Wharfedale PowerCube PC-10
Questions and Unsolved Problems for Wharfedale PowerCube PC-10
Do you recommend Wharfedale PowerCube PC-10 Subwoofer?
Answer
Answer
Hi I just reconnected my KLH surround sound system and found the subwoofer makes a loud hum. Ive... (More)
Answer
intermittent . does not always come on
Answer
my grandaughter pressed something and now the phone says unregistered. Ihave followed the... (More)
Answer
its been getting quite frustrating considering i've spent quite a bit of money on my sound system... (More)
Answer
Hello, Thanks for your support but main problem is i bought it in Abudhabi, UAE and now i am in... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Home Theater... Experts
Top Audio & Video Equipment Repairmen
in , AR
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
