Kitchen Appliances - Others Logo
G
Gary carter Posted on Oct 25, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I Set temp on old uline ice maker - Kitchen Appliances - Others
Peter Hampton
Level 2:
Habit-Forming:
  • Expert 193 Answers
  • Posted on Feb 03, 2016
Peter Hampton
Expert
Level 2:
Habit-Forming:
Answers
193
Questions
0
Helped
79388
Points
348
5 Related Answers
Anonymous
  • Posted on Jul 12, 2008
SOURCE: BI-95 ULINE
raritan eng/whirlpool ice maker assembly
Anonymous
  • 10 Answers
  • Posted on Dec 19, 2008
SOURCE: Uline ice maker not cool enough to make/keep ice
one of two things
1. fan under unit stopped up or quit
2. small freon leak usually in freeze plate
Anonymous
  • 11 Answers
  • Posted on Dec 23, 2008
The trough gets refilled on each ice cycle, if it's circulating, then the water supply is adequate.Y
The exact model would be helpful, but you could call 1-800-779-2547 U-Line's tech line
or email [email protected] for help
http://www.U-Lineservice.com
Anonymous
  • 286 Answers
  • Posted on May 13, 2009
SOURCE: uline ice maker clr2060- makes ice continuously,
This is a problem when the thermistor in your icebin is not being satisfied.Now there is a break in the serial number to find out if you have a thermistor or a mechanical thermostat. If the serial number is before 03 (first 2 digits is the year)and the 2 digits between the dashes is 11(the month) the replace the bin thermostat. If newer then you need to replace board and thermistors.
Anonymous
  • 286 Answers
  • Posted on May 15, 2009
SOURCE: Ice maker (Uline) just stopped working, not freezing, no noise.
U-line does make compressors as long as its not a r12 system. As far as the icemachine turn breaker off for a couple of min then try it. If same results then it could be a board.
1helpful
My ice maker gets cold but will not make ice
I assume you have a good water supply ti the unit.
An internal switch of thermostat may have failed inside the ice maker head unit.
A good repair shop should be able to fix it.
If the unit is several years old it may be best to replace the icemaker.
Make sure they are factory authorised to fix uline products.
1helpful
I have a Uline CLR 2160 ice maker. I am trying to
Your display will only show ice or off. There is no temperature settings.Now when I give the directions to put it into clean make sure the green led above the symbols is on steady. If you hold down the on/off key and hit the light key 3 times then release the on/off key last.(give a 1/2 second delay from releasing on/off key. It should go to CL. If led lights dont comeon then let me know.
Ice maker keeps blowing relay/overload
This could be a faulty relay or a bad compressor. If under 5 years old and your the original owner then call u-line for assistance. 800-779-2547
Uline icemaker compressor runs very hot - slow ice production
if the ice production is slow first try to set it on a warmer temperature. Now if its frosted up then you will need to defrost it. Also check the fan to see if its running. if yes is the condensor clean? If yes then check temperature in bucket. 10 to 15 degrees is ideal for this model.
Wiring came unplugged need wiring scematic for uline ice maker
wiring diagram is on the back of the machine. If you have clear ice maker it may be on the back of the front plate.
2helpful
one of two things
1helpful
2answers
BI-95 ULINE
Top Kitchen Appliances - Others Experts
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
