Cleaning out the ice only lasts for 2 days, Before it starts Icing up again. The Unit was level then raised front to force any water to flow to the back towards drain tube this didn't work either. Is there a heater element under the trough that keeps the ice from forming?
Not usually, will have to thaw, then run pan of hot water through drai. Can pull lower vent cover off to make sure it runs into drain pan under fridge. Drain may look clean but tube may not be. Can take wire from hanger to clear as well.
Testimonial: "Ran hot water through tube and it is not plugged."
