My SB-800 will not sync with my D-70. The display shows MRPT ARPT BRPT CRPT all the time. The flash will fire when the shutter is released on the camera but it will not sync. It will not flash the when the flash button the back is pressed. None of the select functions work.
I had the same problem. You locked your flash by mistake if you have a lock symbol on your LCD. Press the ON/OFF & Sel buttons simultaneously & the lock symbol will disappear. Then reset your unit by pressing Mode & ON/OFF simultaneously for 3 second & you are good to go!
Posted on Mar 19, 2008
The first thing you need to do to correct this problem is to turn your flash on, then push and hold the SEL button.
A menu will come up that will have a picture of two arrows that are shaped like a backwards S (see the picture on the swivel part of the head). These two symbols will be one on top of another with what looks like two flash heads next to it. Move the arrow to select this menu item and hit the SEL button again. On the side menu move the selection to off. Then hit the on/off button and that's it. You should be back to your normal settings.
Hope this helps!
Posted on Feb 23, 2008
Defective main circuit baord
Posted on Feb 06, 2008
Feb 21, 2010 | Nikon Speedlight SB-800 TTL Flash
Oct 20, 2009 | Nikon Speedlight SB-800 TTL Flash
Sep 26, 2009 | Nikon Speedlight SB-800 TTL Flash
Jul 05, 2009 | Nikon Speedlight SB-600 TTL Flash
Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
Dec 27, 2008 | Nikon Speedlight SB-800 TTL Flash
Aug 02, 2008 | Nikon Speedlight SB-800 TTL Flash
Jul 27, 2008 | Nikon Cameras
May 29, 2008 | Cameras
Oct 22, 2007 | Nikon Speedlight SB-800 TTL Flash
Nov 20, 2013 | Nikon Speedlight SB-800 TTL Flash
420 people viewed this question
Exactly the same problem occurred last night with my SB800. There is just no way you can select the mode and the flash button also doesn't fire the flash.
The same thing happened to a friend of mine and he removed the batteries and left it for 2/3 days. That fixed the problem, so that is what I will do now.
