Probably a failing gasket:
PDF]Operator's Manual - Echo Inc.
www.echo-usa.com/...0d3b.../PB500HTes1112_111309.pdf
Echo Inc.Nov 18, 2011 - Additional or Replacement Manuals . .... Install Blower Pipes/Stick Handle . ...... also cause premature deterioration of fuel lines, gaskets, carburetors and other .... Use lower speed to blow dry leaves from walks, patios and.
SOURCE: starts first time, no smoke on normal running,
It could be a coolant or transmission fluid leak in the combustion chamber. Check your coolant and transmission fluid to see if one or both are low. White smoke from the exhaust is a classic symptom of a blown head gasket, have your cooling system pressure checked. If that checks out good then have your transmission checked.
SOURCE: white smoke coming from exhaust when accelerating
This is usually an indication of a bad head gasket.I gasket. The white smoke is the coolant leaking out of the engine and winding up in the oil passages, due to a bad head gasket. To confirm this,
1. check oil. Is level increased, or milky appearance?
2. Is coolant level dropping, but u don't see any signs of leaks?
The above indicates a bad head gasket, causing the white smoke u describe. Let me know how u make out.
SOURCE: heavy white smoke when accelerating sluggish and
if its a bittersweet smell its a crack cylinder head or a leaky head gasket give these websites a try www.alldatadiy.com and www.autozone.com if all fails stop by your local library and get your hands on a Haynes auto repair manual for your SUV wish you the best of luck Michigan Man.
SOURCE: car is overheating and throwing out white smoke
You have a bad head gasket or valley pan gasket
