1. To reset MAINT reminder light after engine oil replacement, turn ignition switch to OFF position with odometer showing ODOMETER READING. Turn ignition switch to ON position while holding down trip meter RESET button.
2. Hold trip meter RESET button down for at least 5 seconds until odometer indicates "000000" and MAINT reminder light goes out.
Turn your key to the on position but don't turn over the engine and have your oil meter showing in the cluster then depress the gas peddle all the way to the floor 3 times the oil meter should then reset to 100%
It means it's time to get the oil changed. It should be at 100% after it is changed and it will decrease over the mileage you drive to let you know it's getting close to change.
When you push the button tn your tripometer on the dash, it will show you the tripometer. push it again and it will show you the oil life expected value of your Engine Oil. Just push the button again for about 5 to 8 seconds and that will reset the Oil meter. Good luck
