Cars & Trucks Logo
Albert Yamaletdinov Posted on Jul 04, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have saturn ion3 sedan 2005 . My stop light not working. I checked the switch and fuse. They are OK. But didn't find relay. Where I can find it? Thank you.
  • Cody
    Cody Jul 04, 2015
    Hi Albert Yamaletdinov, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Did you verify that the bulbs are good? There may be more than one relay panel in the car.
Jeff Armer
Level 3:
  • Saturn Master 15,575 Answers
  • Posted on Jul 04, 2015
Jeff Armer
Saturn Master
Level 3:
Answers
15575
Questions
Helped
7112185
Points
73899
The 15-amp STOP fuse located in the body control module (BCM) supplies battery positive voltage to the normally open stop lamp switch. When the driver presses the brake pedal, the switch contacts close and battery positive voltage is supplied to both left and right stop lamp assemblies and the center high mounted stop lamp (CHMSL), through the BCM. The stop lamps are grounded at G401 and G403.
Do you know where the BCM is located ? If it should come down to it that the BCM needs to be replaced , It has to be programmed an the dealer is your best bet !
Replace the BCM. Refer to Control Module References for replacement, setup, and programming.
There is no relay ! !
1helpful
3answers
Can't find stop lights relay
There is no relay , the BCM - body control module controls the lights !
Which feul switch is for the sensor for the 2005 Saturn relay
ok, your other question was too vague or you posted that question by accident without the specifics
this fuse for your fuel pump for your 2005 Saturn Relay minivan is in your owners manual, i'll link a pdf version in case you don't have one in the glovebox
http://www.saturn.com/content/dam/saturn/northamerica/usa/nscwebsite/en/Home/Owners/Owner_Resources/Manuals/en/us/2005/relay/2005-saturn-relay-owners-manual.pdf
page 5-12 shows you where the fusebox is under-the-hood. you want this one vs the other one inside the passenger compartment.
goto page 5-100 for the diagram of the fuse locations. you should also have this same diagram printed on the fusebox cover.
fuel pump fuse is postion #2 on that diagram
fuel pump relay is next to the horn relay
We have tried everything to stop the dinging in our 2005 Saturn Relay how can we stop it?
You mean the door ajar alarm ?
You could probably pull the fuse for the interior lights to make it stop.
Chances are one of the door sensors has failed.
The PSD fuse is for the power sliding doors.
Renault espace 2005 headlight relay.Help where is it,
Checked fuse ok / checked stalk ok / checked wires at stalk none cut / checked relay ok so where do I go from here?
1helpful
2answers
07 Pontiac G6 (4 door, sedan) all 4 windows won 't work. Fuse is ok.
fuse ok but may be the relay is not ok sir
check the power windows relay
and have a good day sir
1helpful
I just bought a 2000 Saturn SL 4-dr sedan. It's in great shape, but the horn doesn't work and the dashboard light don't work. Is this a simple fix with replacing the fuses or dash light or is it a little...
Check fuse for horn and for dash lights. If the interior lights work then suspect dimmer switch for the dash lights. If you press the horn button do you hear a click under the hood or inside the car? If you do not then the fuse is blown and if the fuse is good then the relay may be suspected bad. If the fuse is good and the relay clicks then suspect the horn to be bad. If fuse is blown and you put a new one in and you push the horn and the fuse blows again, then disconnect the horn before replacing the fuse again. Then push the horn button and see if you hear the relay click if you hear a click the the horn is bad or wiring butmost likely the horn. If you have the horn unplugged and the fuse is good and you push thee horn button and no relay click suspect the horn button to be bad. Hope this helps.
2helpful
2answers
My windows stopped working on my '97 saturn sl2. I have checked the relay switch and it was ok. I changed out the relay switch and still nothing. There is no fuse under the hood. Any ideas on what to do?
There IS a fuse under the hood...the green 30A big boy labeled power/convenience. Use a multimeter to check power coming into the relay...if it's not there probably the fuse. If it is there, could be the switches.
If it's the fuse, go to a junkyard and get one cheap. But then, they're pretty cheap new too.
Startup hestitation, check engine light 2006 Ion3
Since your "check engine" light is on you can get a free scan at Autozone or Oreillys. They can sell you a part and may have a diagram about where it fits. Just speculating it may be a coolant temperature sensor.
It sounds like you are not getting into the Cold Start mode.
1helpful
1helpful
Saturn 1999 One set of head lights won't go
if your lights are dim,your regular lights are not coming on.raely but possible that both lamps blew. the daytime running light module is probably the cause.it has a relay inside of the sealed box and they freeze up sometimes.if your dtr works,the high beams should as well. these are things to check....bulbs,the fuses,wiring and the daytime module.modules are about 100 bucks or so,and if you follow the headlight wiring sometimes you can find it.
Top Saturn Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Saturn Expert? Answer questions, earn points and help others
