Zeepad 9xn plugged in for 48 hours, it will turn on to boot up, then beeps three times, and shuts back down. When I plug it in nothing happens. Any ideas what I can do to get this working again?
If this happened all of a sudden, it may have gotten a power surge. It may also be the battery that has failed. Will it turn on when you have it plugged in? If it won't there is a problem with the unit itself and not the battery.
You must first charge your Zeepad for a minimum of 9 hours prior to using it for the first time. Though it may show that it is fully charged after 4 or 5, you must leave it on the charger. When you go to turn it on, you must hold the power button for at least 3 seconds.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
I would try shutting down the computer in the normal way, and turning off the monitor. Boot up and turn the monitor back on. If it still doesn't work, then I would check the cables and power plugs and wall plugs. Check the mouse and keyboard cable and any other cables plugged into the computer. The next step requires a seperate monitor or laptop. Try unplugging the monitor and pluging in another monitor. Most laptops have a common VGA adaptor jack or even an Svideo jack. If the other monitor does not work, Then take to a qualified technician for repair. It could be your power supply in the computer or video controller.
I hope this was useful and please comment if this was helpful to you.
