SOURCE: Extremely high head and suction pressures
disconnect the blower and turn on the ac.see if the coil frosts evenly.when you had the system open,you should have changed the liquid line drier.
SOURCE: high head pressure, normal suction pressure
Get out there and shut off the power to the Condenser. Pull the shroud off (or all the sheet metal) and clean the fins of the condenser coil inside and out, do this once a year. Use normal water hose pressure, watch that you do not get to close so as to not bent the fins, and be careful of the electrical parts, let it dry before restart.Watch out when you cut grass around it, its best to cut grass with the a/c off, the fan sucks air through the coils, from outside to inside, up out the top. If you call me to do it I will bill you $92.50. Save your money, take your time. Be careful!!!!
SOURCE: new goodman 2.5 ton 14 seer with txv. suction
it is fine and sounds like it is running at a high efficentcey. I wouldnt worry about it as long as it dosent cycle too much.
SOURCE: Goodman Condensor cplj48-1 Air handler Modle
It sounds undercharged (needs more refrigerant). Based on the conditions in your post and assuming the indoor humidity is within 20-70% range, your target superheat should be 10degF. Your superheat (assuming you have an R22 system) is far too high. The pressures are not indicating a restriction; therefore, I have to conclude you have a low charge. A low charge will cause a gurgling sound due to the refrigerant in the liquid line is vaporizing prior to reaching the Cap tube at the Air Handler.
I hope you find this information helpful to you moving forward. :-)
SOURCE: temp off air coming out
Hello, what is your high side pressure? A bad compressor will show abnormally high low side pressure with abnormally low high side pressure. That 45 low side pressure is low And superheat high. If you high side pressure is normal toma little above normal but the low side remains low you have a restriction in the system, that might be why it's not taking in tne freon. Let me know you high side pressure
