SOURCE: Tacsew T500 : Needle continually comes unthreaded
No this machine does not use a bobbin. I just purchased one too and called the supplier to help me keep mine threaded. He said they do not take much tension at all. So check your tension and then when threading it, make sure your thread goes under the bar in the center of the tension disk, not on top of.
Good luck, once you get it going it does a beautiful job!!!! Love it, Love it!
SOURCE: tacsew t111-155 sewing machine skipping stitches
I don't have firsthand knowledge of this machine, but the machines I've used would do this when the thread tension was too high. Check the thread path for any dirt or buildup of fuzz from the thread. Also, check to make sure the thread tension adjustment isn't set too tight. Gently tugging on each thread one at a time may reveal which thread is binding and make your search more efficient. I hope this helps.
