Cars & Trucks Logo
John D Sanford Posted on May 05, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Driver and middle brake light dont work on 2005 sebring all other lights are fine whats the problem
Harrie
Level 3:
Top Expert:
  • Cars & Trucks Master 6,746 Answers
  • Posted on May 05, 2015
 Harrie
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1286103
Points
83153
You also should check the cabling, and the returns. The minus is supposed to go to the chassis of the car. When the connection is bad, the lights won't work. Use a multi meter to find out if the bulbs get any voltage. If not check the cabling, if yes, replace the bulb.
Stuart Kirby
Level 3:
  • Cars & Trucks Master 880 Answers
Stuart Kirby
Level 3:
Answers
880
Questions
0
Helped
214342
Points
1687
5 Related Answers
Anonymous
  • Posted on Dec 19, 2008
SOURCE: 2005 Corolla LE brake lights not working
to ss1957, i have exactly the same problem as yours. At first i thought the bulbs of both side are okay because the filaments (there's two on each) are intact. It turned out that they're not. The brake lights came back as soon as I replaced the bulbs.
Anonymous
  • 840 Answers
  • Posted on Jan 31, 2009
SOURCE: 2003 gmc envoy xl brake lights dont work
sounds like a fuse look under the dash panel for fuse cover look at the back of cover and check that fuseThanks for using fix ya Please rate my response thank you very much
Anonymous
  • 3 Answers
  • Posted on Apr 12, 2009
theres usually a pressure switch behind the brake pedal, sometimes the plastic hex nut rattles loose and you have to retighten it.
Rod Davies
  • 150 Answers
  • Posted on May 03, 2009
SOURCE: 2005 Toyota Sienna rear brake light problem.
have you checked the earthing continuity-if it's this other bulbs may also partly light when brakes used
otherwise-
Check continuity of live from center to lh & rh lights and/or is there a live at those lights
Anonymous
  • 7 Answers
  • Posted on Jun 23, 2009
SOURCE: 2005 odyssey brake lights
all brake lights should be linked to same fuse, so fuse should be OK. check for blown globes.
So i have a 2007 Chrysler Sebring, all the lights work normally except the brake lights.
Your not going to like hearing this one ! The brake lamp switch is an input to the TOTALLY INTEGRATED POWER MODULE ,then the module turns on the brake lights ! It's possabal there is a DTC - diagnostic trouble code stored , this would not have anything to do with the check engine light .
2answers
Honda Civic Brake light Problem
sounds like a bad earth/ground to me, common fault with brake lights
Chrysler Sebring 2005 sedan lighting issues!
It is very much important to take care of your vehicle's service routine to keep it in good condition. If your rear and panel lights are damage then you should change it immediately by mechanics.
http://www.dutchgrown.com/
1helpful
2005 Chrysler Sebring Brake and ABS lights are on, car beeps when I start it
Someone will need to scan the body computer for trouble codes to proceed. The ABS system uses the regular hydraulic brakes to function.
1helpful
2answers
My brake light and blinkers on the tail loights dont work and its not a light bulbs...what can it be its on chevy malibu 2005 and as i look and search its not a fuse because chevy malibus 2005 dont have a...
i dont know where you looked and got your misinformation from. the fuse for a 2005 malibu brake lights is a 15 amp fuse located under the hood in the fuse block. the fuse block is located near the battery.
3helpful
08 Chrysler Sebring Transmission
I assume that you have to press the brake pedal in order to shift from park (ie:safety switch) you might first check to see if you have brake lights as they should be on the same circut and operated by the same switch. If the lights dont work, check the fuses could be a simple fix. Hope this helps
2005 Sebring Convert Radio/light off
I am having this same problem with my 99 sebring.. anyone know what we can do to fix this?
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
