Drills Logo
J
John Barnhardt Posted on Apr 27, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
11247 parts manual - Bosch Drills
John Mock
Level 3:
  • Bosch Master 932 Answers
  • Posted on Apr 30, 2015
John Mock
Bosch Master
Level 3:
Answers
932
Questions
Helped
273722
Points
5591
John,
Try the following link. You may have to register, which is free, to be able to get a parts diagram.
Bosch Power Tools Contractor Tools Accessories
BOSCH 11247 Hammer Drill will drill but will not hammer. Opened the transmission case and no parts broken but low on oil. Could that be why the drill stopped hammering?
Top up the transmission with PAG150 oil. The Bosch stuff is hideously expensive, but it's the same as the 150-grade oil used in car a/c systems. I fill them so the oil *just* covers the big gear.
Bosch 11247 wont hammer
hola le hace falta aceite a los engranes por eso no golpea puedes usar aceite para transmision
2helpful
Plis help with codes to control rcr312w
The RCA code finder can help: http://rcaaudiovideo.com/remotecodefinder/ . Use the drop down menu to choose the RCR312w and then the type of device you want to program. Then click Search.
For example: RCA TV codes to try are 10000, 11447, 10051, 10093, 10679, 11047, 11147, 11247, 11347, 11781, 12002, 12187
Alternatively, go to http://www.rcaaudiovideo.com/remotes/2-3-devices/?sku=RCR312W and click on the Support/Manuals tab. The manual and the code list are both available. The direct link to the manual is http://audiovox2.info/docs/common/RCR312W/RCR312W_OM.pdf . The code list is here: http://audiovox2.info/docs/common/RCR312W/RCR312W_OTHER_CL.pdf .
I hope this helps.
1helpful
I want to use rcr311w remote for rca t25208 tv but couldn't
This remote does not handle combination TV/VCR devices. You will need a different remote. You can get an exact replacement remote here: http://remotes.com/store/rca/t25208.html .
It will control the TV with the code 1000 (most likely). Other RCA TV codes are 11447, 10051, 10093, 10679, 11047, 11147, 11247, 11347, 11781, 12002, 12187. The manual and code list for the remote are available here: http://www.rcaaudiovideo.com/support/?kw=RCR311W . The VCR part uses a code that isn't programmed into the remote. (Remotes generally only have codes for devices released 6 months or more before the remote was programmed. Many of the older RCA universal remotes never had their coding lists updated to include combination units.)
BTW, the manual for your TV is here: http://www.managemylife.com/mmh/owner_manuals/14623/RCA-TV-VCR-or-DVD-Combo-L0109139?brand_name_search=entertainment .
I wish that I had better news.
Looking for the direct tv RC65R remote control code for the RCA LX40FHD41YX9 HDTV
RCA TV codes for the DirectTV RC65 are:
11547, 11447, 10047, 10051, 10093, 12187, 12002, 11958, 11953, 11948, 11922, 11919, 11917, 11781, 11347, 11247, 11147, 11047, 10774, 10747,
10679, 10278, 10174, 10135, 10090, 10038, 10029, & 10018.
Instructions for entering the codes are here.
Instructions for searching for the proper code instead of trolling through that list are here.
If you'd like a digital manual for your RC65, click here.
I hope that helps.
Bosch rotary hammer (model # 11230EVS) drill will not rotate
There is a clutch in the main spur wheel of the unit. These sometime begin to slip, on rare occasions they will slip to the point where the drill will not rotate. If you are interested the part number for this clutch is 1617000817.
Bosch 11247 Hammer drill works in drill mode but in hammer mode it spins as drill but does not hammer. Also how can I remove drive shaft from housing?
Usually replacing the o-rings on the piston, striker and Impact bolt will solve any hammering issues. That is considering there is no damage to the mechanical parts in the hammer mechanism.
2helpful
Need code
rca remote codes:
11447, 10047, 10060, 12002, 11958, 11953, 11948, 11922, 11919, 11917, 11547, 11347, 11247, 11147, 11047, 19747, 10679, 10618, 10278, 10174, 10135, 10090, 10038, 10029, 10019, 10018
Rca remote
rca remote codes:
Top Bosch Drills Experts
Paul Carew
john h
Are you a Bosch Drill Expert? Answer questions, earn points and help others
