You may have to replace your thermostat. If the thermostat is not working properly, you will have over heat. You make also have a bad thermostat gasket and that's where the water leak from. It might be leaking a little at a time and the engine is hot so its dry before you can see it.
If you get scratchy sounds while doing so, the potentiometer needs replacing. If not you could check the solder joints for it and see if its loose. You could just resolder it if that's the case.
on your machine when you select cold, the hot water valve will open automatically letting cold water thru it.can you connect the hot hose up to a tap to stop the water leaking out? or you can buy a screw on plug from a hardware shop that will cap off the valve at the machine or the hose. sometimes to save a customer money i connect their hot hose to the hot valve then fold the hot hose in half and tape it in that position . this stops the water. hope this helps. please reply for further help if you need it
dont open it .if you have hair dryer just use that and give hot air pressure on the spaker and leave it for some time around 2 -3 hours .then use it. Hope this helps. Please rate my response. Thanks. Have a good day.
