Remove the oil sender unit and fit a gauge to see the actual pressure , if ok replace the unit . if not stop and start a few times as the oil pump relief valve may be stuck, change the oil if it has been sitting for six months, DO NOT use it till you fix the fault.
Check your oil level to see if it is not low. If it is OK then you might have a blockage from crude in the oil system. Do you change your oil at normal service intervals?
