2005 Ford Fusion Logo
A
Anonymous Posted on Mar 12, 2015
How do I fix a coolant leak
Its a 1.4 diesel engine
gbob59
Level 3:
  • Ford Master 3,063 Answers
  • Posted on Mar 13, 2015
gbob59
Ford Master
Level 3:
Answers
3063
Questions
Helped
706038
Points
10419
Find leak soon, low coolant will kill a diesel. Keep coolant level correct. Inspect very carefully with a bright flashlight. I like the new Led lights. Look for wet areas radiator hoses, heater hoses water (coolant) pump and Heater coil inside. Do you have any bubbling in the coolant fill tank when engine is running? If so you probably have a Head Gasket failure.
1helpful
Motor oil went up a lot in the crankcase
Assume you mean the engine oil level on the dipstick is getting higher?
I would be surprised if it is hydraulic oil (unless you know different) but I suppose diesel fuel is a possibility though it is many years since I have heard of such a thing, especially if the engine is otherwise running smoothly.
The last time I saw that was on a small diesel engine with a conventional dpa type injection pump driven by oil-fed gears. The pump had sprung a leak and begun to fill the engine. There was no mistaking the strong smell of diesel...
An internal coolant leak can have the same effect but without the smell of fuel.
Coolant leaks 200 series
Part of the water pump bypass connection?
Need to use an inspection mirror,engine off but warmed up.
Possible o ring failure.
Extreme diesel engine vibration shakes a lot of things loose!
Pink fluid is used on late model Toyota's. Honda's is blue.
Universal coolant available,now.
2answers
Leaking coolant from what appear to be the glow plugs in between the exhaust manifold and the valve cover on the passenger side. coolant seeping from around the glow plugs themselves. This is a 2004 ford...
is this engine a direct injection or indirect ,sorry to ask but iam in europe and never seen this engine ,if its a direct injection then it cannot leak but if its indirect then yes you could see a leak but it would go into the engine as well ,because the the injector and the heater are in a side chamber in the actual cylinder head ,its called a ricardo comet type cylinder head layout but is only used on smaller lightweight diesels .
1helpful
2answers
My 99 Saturn SL2 has recently been leaking the engine coolant. Every time I drive it, I need to put in a 1/4 to 1/2 bottle of coolant. It was overheating a couple weeks ago and I replaced the fan motor. A...
Take it to a shop and ask them to put it up on a lift, take a look and figure out where it is leaking. They can tell you and also how much to fix.
I just bought a second hand BMW325TDS.When the motor is idling a bit rough and there is white smoke from the exhaust. Can this be the diesel pump timing? Can I set the diesel pump timing and how do I set...
Priority Action Part Type Cause 1 Inspect Head Gasket Head Gasket Leaking Coolant into Cylinders. 2 Inspect Engine (DOMESTIC ONLY) Cracked Cylinder Block Leaking Coolant into Cylinders.
6helpful
2answers
2004 Ford F-250 6.0 liter diesel loosing coolant
i'm getting "internal control module keep alive memory?" for fault p0603. which i think has nothing to do with using coolant. i assume you're finding no leaks, so it's leaking somewhere you can't see. does it smell of antifreeze in the interior? is the carpet wet? the heater core might be leaking into the interior. there could be a slow leak on the top of the engine and it's boiling away before it has a chance to pool. fill your reservoir fully. let the engine get hot. inspect for steam in the engine compartment.
2helpful
2001 dodge 3/4 diesel truck my heater does not
Hey,
I'll assume for now that the blower motor is working.
Now, there are a couple of things things to check.
1. Easiest thing to check is the coolant level. If the coolant is low, your heater will not give any warm air. Hopefully this is the problem as it's the easiest fix.
2. The thermostat. When the engine and coolant are hot, your top rad hose should be hot as well. See if the rad hose is hot to the touch. If it isn't, your thermostat might be faulty. It's a fairly easy and cheap fix as well.
Good luck.
3helpful
2answers
Running fine, then blew lots of white smoke that smelled like diesel, cut off and won't start again. Dee
If this is a gas engine You have probably blown a head gasket. If its a diesel engine of later years 03 or later you probably have an injector failure and or a injector pump failure. I hope this helps.
Thank You,
Roy
Right Hand Drive 98 Cherokee Sport XJ 2.5L Diesel VM - Coolant Leak
I think the labor to check out the leak is too much.
If a qualified tech. pressurizes the system, he should tell more or less where it's coming from.
Could be freeze out plug.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
