Motorola baby monitors have a manufacture defect on the power button. They have received so many complaints of broken power buttons they actually offer a courtesy replacement past their warranty period. I can not recommend Motorola baby monitors with this defect. Models MBP43 MBP33 etc.
I´m really sorry that the Baby monitor does not work as it should, but you can contact our tech support department For Baby/Home/Pet Monitors, Cordless/Corded Phones, Digital Photo Frames to this phone #: 1-888-331-3383 from Mon-Fri 7:00 am-7:00pm CST or visit us here https://motorola-global-portal.custhelp.com/app/mcp/service/ and Chat Online with one of our representatives who will assist you the with issue that your having with your device or send us an email.
Most portable & laptops with color screens, have screen filters that makes up for this. It sounds like the filter is broken.
Consult the manufacturer or an authorised repair shop.
If its Bluetooth you need to put it in pairing mode by turning The device off and then turn it back on and continue holding the power button until this device power on light stays steady or is Blinking rapidly
We used this monitor for two years with no problems then we also
experienced the same power problem. Using my electronics background I
was able the verify that the problem was with the actual power switch. I
ordered a replacement switch and installed it. The monitor now works
like new again. The switch is available via online electronic
suppliers. The part number I used was a TL2285EE made by E-SWITCH. I
found that it is actually a little bigger then the original and believe
that the original switch is actually a TL2230EE. The bigger switch fit
with a little persuading and should last a little longer but the 2230
would fit much better. This job is not too hard for someone with some
soldering experience.
Good Luck...We love our monitor again (we own two)
would fit much better. This job is not to hard for someone with some
Broken plastic power button?
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you: 1742SED2H 715G1492 2 FR Dell ADTV1742SED2H Power Supply Backlight Inverter...
