How to Adjust a Headlamp Beam on a 2005 Chevrolet Cavalier...
When you replace the headlamp assembly in the 2005 Chevrolet Cavalier, you must also adjust the headlamp beams. Like most vehicles, there are two screws located on the headlamp assembly that control the vertical and horizontal direction of the headlamps. Proper adjustment is necessary for adequate visibility during nighttime driving; bad adjustment can make it difficult for you to see or make it difficult for oncoming drivers to see, creating a potentially dangerous situation. You can adjust the headlamp beams yourself with a screwdriver in about 15 minutes. Park the Chevrolet Cavalier on a flat surface facing a wall or garage door approximately 15 feet away. Park the Car so that it is perpendicular to the wall.
Lift the hood and remove the plastic trim panel above each of the headlights. There are three plastic fasteners that secure the trim panel; pry the fasteners out using a flathead screwdriver. Lift the trim panel up to remove. There are two adjusting screws beneath the trim panel, one on the top of the headlamp assembly and one along the outer side of the headlamp assembly.
Turn the headlights on so that they shine on the wall. Ensure the headlights are on the "dim" setting.
Adjust the vertical bolt, located on the top of the headlight assembly near the center of the vehicle to raise or lower the headlight, using a crosspoint screwdriver. Turn the screw counterclockwise to lower the headlamp beam; turn the screw clockwise to raise the headlamp beam. Adjust the headlamp so that the beam is below a driver's eye level.
Adjust the horizontal bolt, located on the outer side of the headlamp assembly to move the headlamp beam right of left, using a crosspoint screwdriver. Turn the screw counterclockwise to move the headlamp beam right; turn the screw clockwise to turn the beam left. Adjust the headlamp so that the beam shines straight ahead or slightly toward the center of the vehicle.
Replace the plastic trim panel and fasteners and close the hood. Warning: raising the lights too high can make it difficult for other drivers to see you.
to replace headlight bulbs turn steering so you can open flap in the wheel arch.open flap liner to access of the rear headlight unit.to remove inner bulb in headlight housing remove the air intake duct at front of the air cleaner housing right hand side unclip the wiring harness connector unclip the the left wiring harness connector front of fuse and relay.to remove the dipped beam remove the plastic cover from rear of head light unit.through wheel flap opening. rotate bulbholder anti clockwise to remove bayonet fitting remove headlight bulb. WARNING WEAR CLEAN GLOVES WHEN HANDLING HEADLIGHT HALOGEN BULBS OILS FROM HANDS WILL CAUSE HALOGEN BULB TO OVERHEAT AND BLOW OUT.
Are u sure that the bulbs are OK? I had no dipped lights on mine, & thought it must be a fuse or another electrical fault. It turned out, both bulbs had gone. I think this often happens when one side goes, the other soon follows.
If the headlights do no ilinitate when switched on you have a faulty battery or cable conection problem.Jiggle the cables while the headlamps are switched on if they do not lightr up:battery failure.If they do,clean up the connections at the cable to battery and put the on securely
under the hood, near the rear of the headlamp assemblies, there are adjustment screws with phillips head screwdriver slots. They may be hard to see with the radiator support above the headlamps, but they will be the only phillips adjustment screw heads on the whole headlamp assembly. They will be facing directly vertical facing up
ithere are 4 bolts that hold it in...the top 2 are obvious..the others are behind the bumper. the bumper must be removed to acces them...here are the manuals instructions..
Item
Part Number
Description
Headlamp assembly bolts (3 required)
Headlamp assembly nut
Headlamp assembly
Electrical connectors Removal and Installation NOTE: Make sure the headlamp switch and the ignition switch are in the OFF position.
Remove the front bumper cover. For additional information, refer to Section 501-19.
Remove the 3 headlamp assembly bolts.
To install, tighten to 5 Nm (44 lb-in).
Remove the headlamp assembly nut and the headlamp assembly.
