the numbers should move as it's calculating your blood pressure , but once it finnishes the test the numbers should lock in and not change till a new test is made
and somethng thats not in any of these machines manual , allways place cuff in same spot on your arm after rolling up your sleeve i use a freckle as my landmark for this , they dont like to work too well over shirt sleeves
Recalibration normally has to be done by the manufacturer. As they have to certify the calibration. Keep in mind, that it is not unusual for your BP to read a bit higher at the doctor's office, than it does at home. It's sarcastically called "White coat hypertension." Which translated means, your blood pressure rises a bit at the doctor's office due to anxiety. Or it's being taken at a different time of day, than you take it at home, in a relaxed atmosphere.
Part of the problem may the the placement of the cuff. Generally, if it's not placed correctly. the cuff will re-inflate trying to find the correct stopping point for inflation. Any movement of your arm could cause this. Also, if you haven't replaced the batteries lately, you should do that. Also check to make sure there are no air leaks in the rubber tubing or the cuff. Check your Owners Manual for the exact placement of the cuff.
It appears you may have a leak in the cuff. This will need to be verified by an authorised service facility. Contact OMRON they should be able to assist you. CONSUMER SUPPORT TOLL FREE NUMBER: 1-877-216-1333
Customer Service Representatives are available Monday through Friday - 8:30am to 4:30pm CT
