HI if you want to unblock your samsung galaxy s2 mobile from network provider lock to freely use it with any GSM sim then code is the best solution to unlock it .You can purchase code from online providers like Mobile-Unlocker.com for reliable cost .You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone then freely use it with any GSM sim ...
A good tutorial is found here: http://www.wikihow.com/Unlock-Samsung-Galaxy-S-II-%28S2%29
SOURCE: Cannot charge Samsung Galaxy S2
first, test th charger with another phone to confirm if its working or not.
If the rempte is working, then it means the charging port of your phone is defective and needs to be replaced.
Regards.
Testimonial: "Thanks!"
SOURCE: USER MANUAL FOR A SAMSUNG GALAXY S2
http://www.manualusersguide.com/samsung-galaxy-s2-user-guide-manual-pdf-download.html
Hello here is the link where you can download the user manual for your phone. I have downloaded it for you so you dont have to do it but for some reason i cant attached it in here. So instead i give you the link. It is easy jsut go in this site and at the very bottom you will see download samsung user manual pdf. .just click it and you will be downloading the pdf file in no time..
Hope this can help you..have a nice day..
SOURCE: how do i unlock memo on galaxy s2
Hi Andre,
You must gain root access in order to reset the password as there is no other way. If you do not have access, search XDA Forums for instructions on how to root. Rooting procedure for S2 is pretty established and straight forward.
Once you have root, you will need to do the following steps:
Please contact me if you need further assistance,
Thanks,
Hunter Quinn
IBM Technician
1 - Switch ON your Samsung Galaxy S2 with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung Galaxy S2 is locked to.
CODE: Its the unique Unlock Code for your Samsung Galaxy S2.
