My 2009 Sebring does the same thing occasionally but only the drivers door gets stuck (dead locked - even though the locks appear to pop up).
The solution I have found once this happens is:
1) The car needs to be driven (crawl in thru the passenger door) -even just a short distance
2) Engine shut off & doors locked with remote (after you've exited from the passenger door of course)
3) Leave turned off for 10 minutes
4) Doors will now open when unlocked with the remote
if you talking about door latch wont let door close.try to reset all door locks.first if you cant get door close.work unlock button with remote or door switch.then hold open door handle while you flat screw driver pull up latch in door latch should stay up so door will close.once get door close.try resetting all door locks by sitting inside vechicle with all doors close.remove key from ignition.open drivers door.wait 24 seconds.turn ignition switch on and back to lock position 3 times.press and release drivers door courtesy light 3 times.ensure doors lock and unlock.if not wait 40 seconds and repeat procedure.if this procedure fails. you have problem in the door latch and lock mechanism inside the door itself.
it is not the actuators, try a different remote, you may have an issue with the car security system/body computer not functioning on the unlock driver door command, one press of remote is unlock driver door and 2 presses is unlock the other doors.
turn key twice when opening, ie turn right. once drivers door will unlock, turn twice passengers doors will unlock, and locking is turn anti clock wise once will lock all doors, turn twice will set door dead locks.dead locks will stop openand lock internal button working and handle from opening door. the same actions can be applied to the remote one press drivers door, two press passenger doors, press and hold unlock button for 5 seconds and rear window will open.
1. sitting in driver seat, with driver's door OPEN, press lock/unlock
button ON THE DRIVERS DOOR to lock all doors, then manually unlock
driver door only. 2. Insert YOUR key in ignition, DO NOT TURN, then remove key. 3. Using the same lock/unlock button ON THE DRIVERS DOOR, slowly press lock-unlock in 5 cycles 4. Shut door. 5. Open door. 6. Using the same lock/unlock button ON THE DRIVERS DOOR, again slowly press lock-unlock in 5 cycles 7.
With the door open insert your key into the ignition, turn to 'on'
position (DON'T START), wait 5 seconds. Turn off and remove key. 8.
Locks should cycle once (Car will lock and then unlock once by
herself). If they don't cycle or they cycle more than once, do steps
1-7 over. 9. Now using the remote, push lock button, hold for one
second, then release the button. The locks should cycle once. If not,
start over and go slower. 10. Close the door. 11. Open the door. 12. Press the lock button on the remote. The locks should do a lock-unlock cycle. 13. Close the door 14. Press the lock button on the remote, the doors should lock. 15. Press unlock button and the doors should unlock.
1. Driver's door OPEN and unlocked, all other doors closed and locked.
2. Insert YOUR key in ignition, DO NOT TURN, remove key.
3. Using the MANUAL lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
4. Shut door.
5. Open door.
6. Using the lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
7. With the door open insert your key into the ignition, turn to on position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once). If they don't cycle or they cycle more than once, do steps 1-7 over.
9. Now using the remote, push lock button, hold for one second,
release. The locks should cycle once. If not, start over and go slower.
10. Close the door. Open the door. Press the lock button on the remote. The locks should cycle. Close the door. Press the lock button on the remote, the doors should lock. Press again and the doors should unlock.
1. Start with key out of ignition, drivers door is open all others closed and drivers door is unlocked. 2. Insert key into the ignition (DO NOT Turn) and Pull key out. 3. Perform these steps within 40 seconds. A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles starting with lock. Use an even pace and try to go about one cycle per second. (1Cycle = 1 lock and 1 unlock). B. Close, then open drivers door. 4. Perform these steps within 40 seconds. A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles starting with lock. Use an even pace and try to go about one cycle per second. (1Cycle = 1 lock and 1 unlock). B. Insert the key in the ignition cylinder. C. Turn the ignition to ON (Do NOT Start) then back to OFF. D. Remove the key from the ignition. 5. Press any button on remote for a minimum of 1 second. System should now lock and unlock doors once.
6. Close and open drivers door. 7. Press any button on remote for a minimum of 1 second. System should now lock and unlock doors. Once to confirm programming, twice to indicate programming failed. 8. Repeat steps 5, 6 and 7 for additional remotes.
