Most likely it is in the gas tank
The fuel pump is located in the tank
Gas is in the tank. Two tanks, two pumps. And a switch on the frame to go back and forth from tanks. With a manual switch in the dash. Rarely do both pumps go bad at the same time. It is either the dash switch or transfer switch. Diesels also have two pumps. One pulls the fuel from the tank to the injector pump. The injector pump is the second, it delivers the fuel to the injectors. On diesels other things have to happen before the injectors work.
SOURCE: 1997 Chevrolet Silverado Fuel System
Hello Johnholley
I am wondering do you hear the fuel pump when you just turn the key into the on run position not crank just in run and listen and see if you hear the fuel pump run for a second, If you don't hear it you will want to check for power at the fuel tank, and have some one cycle the key while your under the truck with a test light. Hopefully you have power and you hear the fuel pump run. Now if you do hear the fuel pump running then the next thing you will want to check is for spark, It could be the ignition module or pickup coil. check out those thing and I am sure you will be able to figure out whats going on. If you don't get back to me and we can try a few other methods. I sure hope that helps you out johnholley. and thanks for using Fix Ya Bear001
SOURCE: intermittent no start, very strange, very confusing
Sounds like fuel pump going out. I was told by a friend that the pump can get stuck and that by knocking on the fuel tank or by attempting to start that it can kick the pump out of the bad spot and it will start. But it is a sign that it needs to be replaced.
SOURCE: Where is Fuel Relay for 2004 Dodge Ram 3500 Diesel Truck
it doesn't have a fuel pump relay it has a fuel pump control unit and it is located on the chassis back quarter drivers side near the tube cross member for chassis on top of chassis rail near bed mount. locate the rear springs front perch and it will be above that on top of rail.
hope this helps. good luck and please ask any question you have.
Testimonial: "Thanx for info..no wonder I couldn't find Relay! "
SOURCE: 1999 cadillac catera I was driving and car killed
it's definitly the crankshaft position sensor, i've had the same problem and it took my mechanic almost 2 hours to find the problem, i hope this helped you
SOURCE: My 2004 Kia optima recently died while being
Then you have a intermittent spark . Now do you have a spark tester to test spark. Its okay if you dont we have one . Oh by the way you did the fuel pump yourself. if you can do a fuel pump then you can do this to solve the no start problem. No spark tester? okay we will use that tachometer (RPM gauge). crank the engine does the tach meter reads zero at all times while cranking, if it does youll need a crank sensor. Here the story Rough running conditions and or stalling was caused by a faulty crank sensor, try shaking the connector or wiggle the crank connector then see if it starts. Youll need to inspect the connection for proper male to female connection these have been the most suspectable failure of KIA. If you decide to replace this sensor make sure connections are good, more than likely this was the problem and not the fuel pump
