Torch in inch pouds and pattern to follow
The removing of the bolts to the valve cover isn't that crucial in what order you remove them and the torque is only around 25lbs max , if you mean the cylinder head follow this link and click on TORQUE TABLES
http://www.speedwayautoparts.com/index35.htm
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pan-on-2008-honda.html
How to replace Oil Pressure Sensor on 2008
Honda Odyssey?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pressure-sensor-on.html
2004 Chevrolet Express Van: Oil pressure
sending unit replacing?
http://whoisbyme.blogspot.in/2012/06/2004-chevrolet-express-van-oil-pressure.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to
Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
HOW
TO RESET OIL CHANGE INDICATOR?
http://whoisbyme.blogspot.in/2012/07/how-to-reset-oil-change-indicator.html
These details will help.
Thanks.
