SOURCE: Crank positioner sensor on a 2005 cavalier 2.2 ecotec
hello , yes it does . otherwise known as the CKP
a picture of its location is this link .
http://www.autozone.com/addVehicleId,2968401/initialAction,repairGuide/shopping/repairGuide.htm?pageId=0900c152800a2490
SOURCE: cant find my crank position sensor on 97 chevy cavalier z24
On 2.2L 4CYL VIN[4] It's located on rear side of cylinder block below coil module.
On 2.4L 4CYL VIN[T] It's located on front side of cylinder block almost dead center.
SOURCE: tps sensor on a 2002 chevy cavalier
Find where the throttle cable goes the the throttle body. Now on the opposite side of the throttle body is the TPS 3 wires/plug.
SOURCE: where is the iat sensor located on a 1999 chevy cavalier 4cyl
The Intake Air Temperature (IAT) sensor determines the air temperature
inside the intake manifold. Resistance changes in response to the
ambient air temperature. The sensor has a negative temperature
coefficient. As the temperature of the sensor rises the resistance
across the sensor decreases. This provides a signal to the PCM
indicating the temperature of the incoming air charge. This sensor helps
the PCM to determine spark timing and air/fuel ratio. Information from
this sensor is added to the pressure sensor information to calculate the
air mass being sent to the cylinders. The IAT is a two wire sensor, a
5-volt reference signal is sent to the sensor and the signal return is
based upon the change in the measured resistance due to temperature.
Fig. 1: The IAT sensor is located in the air cleaner outlet
tube-2.2L engine and 2.4L engine
Hope helped.
