Cars & Trucks Logo
g
gladys mrivera Posted on Oct 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Looking for spindle for my mcd 703/37 phillips, do you have in stock???
Chris Hunt
Level 3:
Genius:
  • Cars & Trucks Master 1,342 Answers
  • Posted on Oct 29, 2014
Chris Hunt
Level 3:
Genius:
Answers
1342
Questions
0
Helped
177007
Points
4674
Fixya does not sell auto parts. Have you tried Rockauto.com?
What are rear spindle rods for 2007 Chevy Impala
Stock Wise Auto a little over $27.00.
Ive replaced a stock spindle with a drop spindle on my 95 gmc sierra and i can't seem to get the rotor on the spindle far enough to put the spindle castle nut on?
just remove the spindle as it slows the speed of your engine thus making it to consume a lot of fuel over a short distance
I need to remove my rear door panel to replace the stock speakers
removing the panel is easy remove (ALL) the Phillips screws you
have to look real hard they hide some of them you will need a tool
that you can rent from autozone its a flat tool with a cut out in it
the counter person will show you how to use it once the screws
are out you can pop the buttons with the tool and the panel will
come right off
i hope this helps you
bob
How to change a 2003 mini cooper wheel bearing
Remove the wheel then remove the brake caliper and rotor, remove nut from lower balljoint split balljoint and control apart,remove the cv nut from axle then pull spindle back and slide cv shaft out of spindle,next on the rear of the spindle remove the bolts that hold bearing to spindle then use a hammer to tap bearing out of spindle here a picture to help you locate the bolts on the spindle and to see what it looks like,984d3b5.jpg
1helpful
2000 Ford Focus LX steering knuckle/ball joint
theres 2 ways too fix that!! one is get some brass shiw stock it comes in a roll get about .005 thick! wrap several layers around the knuckle pin where is goes into the socket and then tigthen it up that will remove the play also you can heat the socket with a torch and then take a hammer and shrink the hole opening but if you call beards salvage in tulsa okla they can and will sell/ship you one
2helpful
Lower dash removal of 93 vw cabriolet to change ignition switch
You'll need to remove the steering wheel, 15/16th inch socket, the column top and bottom cover, remove the 3 screws holding on the turn signal and wiper stocks. Unplug and remove the stocks. Remove the black plastic sleeve on the hub. Remove the 1 allen bolt holding the lock cylinder/switch assembly. Remove assembly, there is a phillips screw holding the ignition switch in the assembly, remove that screw and pull out the ignition switch.
3answers
2000 Alero
3157
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_00678fd4800d19c5
Front Differential
go to your local chevrolet dealership and check with the parts dept. tell them what you are looking for and they will give you the factory gm part# to the tool and they may have in stock. this is the best way to get the proper tool. parts stores sometimes are not the most knowledgeable on there spaciality tools they can get unless you can speak to someone who has been there awhile. good luck happy wrenching
1986 F250 4X4 inner rear wheel seal is not stock
You can carefully remove the old sleeve, careful not to damage the surface underneath, inspect and assess the damage underneath. Possibly it can be repaired properly with medium then fine emery cloth polishing the surface. If there is a groove deep enough that your thumbnail catches on it, you might need to install a new sleeve. Research the brands and install the thinnest one possible. You may also be able to drive the seal in deeper or shallower to locate it in a different position on the spindle. It would only need 1/8 to 3/16" difference. Please post your results, hope this helps.
-Jeremy
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
