HP Aloe-GL8E 537376-001 motherboard Foxconn H-RS880-uATX AMD Socket AM3 Athlon II x2 3.6ghz 2gb DDR3 450 watt thermatake power supply
SOURCE: Power keeps shuting off while installing Windows
It sounds like some-thing is overheating, an over stressed power supply or poor ventilation could be your problem.
See your power supply is Max 300W that's peak not continuous power output. I think it will only be able to continuously output around 250W of power. Which is below specifications for your computer mainboard.
The Cooler Master Extreme Power Plus range of Power supply's are an excellent choice.
I would recommend a 460Watt with 120mm fan at least.
damnor01
SOURCE: I have a HP HPE-210y
Welcome to Fixya. If you want to go to the BIOS screen reboot the computer and on the POST Screen Tap Delete Button on your keyboard.
You can also the the messge on the Post screen to Press the DELETE button to go to Setup.
If you have questions please let me know. Thanks for using Fixya.
SOURCE: Where can I find a BIOS update for Foxconn H-rs880-uatx (aloe) motherboard
here is the most upto date bios file for the Motherboard which is 6.09
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&dlc=en&softwareitem=pv-88054-1
