Lights work,radio powers on but no sound to the speakers. Also after trying to start and key is removed cluster lights remain on faintly even when key is removed.If I remove battery cable they go off but happens again when I reinstall the cable and try to start it again.
SOURCE: try to start car and nothing happens. replaced
Do the dash lights come on ? They should come on when the key is turned to the on position. If nothing happens check the engine relay. It is not too expensive to replace if you really want to eliminate that as the problem. Check all wires going to the starter and make sure it is wired correctly.
SOURCE: can't remove key from ignition. battery is dead
If the battery is dead, the ignition keys will not release from the ignition. If there is no signal from the transmission shifter that it's in park since the battery is dead, then the ignition lock will not release the keys. After charging the battery or jumping the blazer to start it and the key's still will not release, try this.
There is a "plunger" as part if the ignition. Under the steering wheel there is a small removable cap that you can take off and put a small screw driver up into and press the plunger in and it will release the key. Good luck and hope this helps, Keep me posted be glad to help.
SOURCE: 2003 Chevy Impala periodically won't start
Try under the dash, attached to colum is a switch that the rod goes into from your ignition key switch, that may need to be adjusted tword your steering wheel just a touch, they go out of alignmnet from time to time
SOURCE: 2001 ford Taurus. Will not start. Turn key and
The problem would be the starter they go without any warning
Testimonial: "Terian5- Thanks for the help Traced the wire to starter. the wire looks like it snaps on. put it back and it started. I need to tighten nut."
Ignition Switch Will Not Turn Off?
http://schematicsdiagram.blogspot.in/2012/04/ignition-switch-will-not-turn-off.html
1995 Ford Taurus: Ignition switch not turning OFF?
http://repairhelpcenter.blogspot.in/2012/06/1995-ford-taurus-ignition-switch-not.html
Ignition Problem Troubleshooting
http://whoisbyme.blogspot.in/2012/07/ignition-problem-troubleshooting.html
These
will help.
Thanks.
