How can you fix not blowing heat, just the cold air blowing thru the dashboard and making a noise of open / closed under the dash board of 1998 plymouth grand voyager 6 cylinder (3.3)
SOURCE: 1999 plymouth grand voyager expresso .3 litre 6 cyl , how do I change the air filter?
Next to the battery & mount onto the upper frame at the front of the car an air filter housing with 2 self tapping bolts. Remove these and disconnect serveral hoses and lift back, Below this is the air filter housing itself. clips are on the side slip off, and replace filter.
SOURCE: 98 PLYMOUTH GRAND VOYAGER WONT START - BLOWS ENG FUSE - HELP
You have a shorted engine harness, this is not common but it does happen, heat and engine movement cause damage to the harness, this is most common on hi miler cars and vans, the only way to fix it is to start by looking anywhere the harness rubs, that is where the damage occurs.
SOURCE: 1998 plymouth grand voyager cruise control relay/fuse location?
Check under hood in box marked fuses & relay, on drivers side and look under cover of it for I.D.
SOURCE: 2000 plymouth grand voyager 3.3 V6, loud noise in serpentine belt area
remove belt and check the pulleys. this belt routing is odd and its very tight. i have seen many failed tensoner pulleys on these. it should spin smoothly and quiet. and grinding or bumpyness in it and i would replace it. check all pulleys while your there. they are not expensive.
good luck,
Michael
SOURCE: Where is hatch sensor for 1998 Plymouth grand voyager (3.3 FLEX)?
its built into the lock mechanism lock might have to be replaced try adjusting it first. should be able to move the latch.
Testimonial: "A true expert. Makes sense to me."
