Here are the torque specs for the flywheel and clutch plate on a 2003 Kia Spectra:
Flywheel: 78 - 80 ft-lbs (106 - 112 Nm)
Clutch plate: 19 - 21 ft-lbs (26 - 29 Nm)
It is important to follow the torque specs carefully when installing the flywheel and clutch plate, as over-tightening or under-tightening can cause damage.
Here are the steps on how to torque the flywheel and clutch plate on a 2003 Kia Spectra:
Install the flywheel and clutch plate.
Use a torque wrench to tighten the flywheel bolts to 78 - 80 ft-lbs (106 - 112 Nm).
Use a torque wrench to tighten the clutch plate bolts to 19 - 21 ft-lbs (26 - 29 Nm).
Reconnect the battery and start the engine.
Check for leaks.
If you are not comfortable tightening the flywheel and clutch plate yourself, you can take your Spectra to a qualified mechanic.
The best thing you can do at this point is get the repair manual. You may find it at your local parts store or purchase it on an internet site. This way you will have all the specs; the main bearing, rod caps, cylinder head, etc torque specs.
My wife has a 08 Fox and her front wipers stopped working it's just a fuse in bank 7 a 10 amp just replace with a new one or swap for the 10 amp fuse in bank 11 (just a warning lamp for the handbrake) until you get a new one. ;-)
no points on ur car (check from the center of distributor cap and follw that wire, it leads to the COIL) and gap is usually indicated under the hood on a sticker. Should be right near the front of the hood (on the underside) or just above the rad.
