Computers & Internet Logo
G
Graeme Hills Posted on Sep 28, 2014
I have a Bauhn Ultima APVR-1000MI. Could you tell me how to move recorded shows from the internal drive to folder on the 1 tb external / usb drive?
Thanks very much Graeme Hills [email protected] +61 4 1461 1521
akbar
Level 1:
New Friend:
  • Contributor 36 Answers
  • Posted on Oct 10, 2014
akbar
Contributor
Level 1:
New Friend:
Answers
36
Questions
0
Helped
15417
Points
61
Open 2 windows one showing the shows on drive one and one in the folder you want to move it to ( make the windows small so that you can see both windows) put the mouse pointer on the show you want to move right click on the mouse chose copy or move. put the mouse pointer on the drive you want to move it to right click the mouse chose paste and wait will it copies or moves to new drive
Note move will delete it from the 1st drive and put it on the 2nd drive
with copy option you will have a copy on both drives
Testimonial: "The Bauhn Ultima APVR-1000MI is a PVR with an internal hard drive not a personal computer. i cant open windows on it. I am looking for a way to do this via the internal menu system."
  • Graeme Hills
    Graeme Hills Oct 13, 2014
5 Related Answers
Anonymous
  • 4102 Answers
  • Posted on May 20, 2008
SOURCE: loss of power on hills
Hi, i think i answered you in another post.
If not then the likely cause of your problem is turbo related the most common cause is one of the pipes going to the turbo has a small split in it causing this problem.
Nearly all the diesel turbo cars with your problem usually means a pipe needs replacing for the turbo this will need to be checked as it can be difficult to find the damaged pipe because they work under high pressure so actually seeing the damaged part can be difficult so check properly.
If you are unsure then get a garage to check this as they will know the fault and will have a good idea exactly which pipe is damaged.
Worst case of this will be that the turbo needs replacing but this is in the most severe of cases the turbo can blow if the pipe has been damaged for to long as it will be working under the wrong pressure.
What happens is when you acelerate the turbo builds up pressure giving you more power when you need it but when the pipe becomes damaged this pressure is lossed and you then lose power and will cause black smoke coming out of exhaust.
Hope this is some help to you but if you have any problems or questions then give me a shout back and ill be glad to assist you further ok
Anonymous
  • 3 Answers
  • Posted on Jun 28, 2008
SOURCE: no power going up hills
there are two conditions
1)
pls clean up ur vehicle's HEAD (which mean the spare part immediate attachment to the engine and keep the Nozzle pressure is high )
2)
Get rebour ur engine I mean replace the piston rings
3) (this is for temporerly)
before the hill u stop ur vehicle for some time (say 15 mts) so that ur engine is get cooled after that u have ur driving
ash seder
  • 166 Answers
  • Posted on Dec 20, 2008
SOURCE: lossing power
not all hdi injectors are the same and there are some tricks to replacing the injectors so be careful as you can cause saver damage to your engine if not done correctly.
as the other gye said it may be a turbo pipe but Peugeots being Peugeot it could be any thing your best bet is take it into a dealer and get them to put it on the PPS to diagnos it properly
Anonymous
  • 99 Answers
  • Posted on Jan 24, 2009
SOURCE: car stalls at abrupt stop, and driving up hills.
fuel pump may be weak
Andrew Portelli
  • 298 Answers
  • Posted on Jul 27, 2009
SOURCE: I have a 1995 Honda Civic. When driving up hills
Check spark plugs and all related cables, fuel hoses, fuel filter (change if black but make sure lines and fuel tank are clean first), and air filter. If blank spots are experienced when power is lost completely then firing of spark plugs may be the issue. Possibly also related to insufficient fuel reaching combustion chamber. Available for more consulation after you do through the above recommended basic checks.
How do usb external drives work
If you are comparing the USB drive to an internal drive, generally the USB drive is slower due to the USB connection not moving data as quickly as a internal hard drive which has a more direct connection to the motherboard. USB 3.0 is a significant upgrade over USB 2.0 in that it can handle higher data traffic.
1 TB is quite large.
1 tb internal hard drive recognised as 300gb?
Please check it:
Control Panel, Administrative Tools, Computer Management (please run as administrator; right click it), Disk Management. What is the information of your 1 TB hard drive? Is there any unallocated space?
Bauhn Manual for APVR-9650T
http://forums.whirlpool.net.au/archive/2211037
Quoting from above:
Bauhn 1TB PVR
model APVR-9650T
a REVIEW
Spent a couple of hours with this PVR, comparing it with an earlier model Bauhn 1TB PVR (AS-PVR1000R, 2011).
Bought on sale Wednesday, $199.
[Only commented on differences between models. Have previously reviewed the older model - which still is a reasonably good PVR.]
Summary: not bad, some good features in a budget PVR, and a couple of annoying issues that weren't in older models (which should be easy to fix in firmware). Works well, responsive remote, although I prefer the button press of earlier model.
But product quality control is worryingly patchy. Bought 2 units, 1 was dead out of box!! Confirms my advice to buy 2 to get 1 that works well. (On power up with good broadcast signal, TV displayed Bauhn logo for few seconds, then blank screen, sound of HDD, and never advanced past "----" on PVR. Tried many times on different video outputs & TVs.)
I'll probably be returning this PVR within 60 days as the few annoying aspects outweigh the added features for my needs, over my older BAUHN PVR.
Features:
Series Record:
Records all programs with that title on that network. (Still assessing if SERIES RECORDs program on more than 1 network - e.g. records Simpsons on 10 & 11, but does it SERIES RECORD Mythbusters on SBS, as well as 7Mate?)
Good if you are away from PVR as it changes recording times to latest EPG (as long as broadcast sticks to EPG times), if program schedule frequently changes, and does not record if program is dropped from schedule.
(I have returned from overseas to find what I had set to record was not what was recorded as the program line-up had changed. SERIES RECORD should solve that.)
But... takes up many available recording schedules including ones you may not want recorded (PVR has maximum of 50 TIMER schedules, so for example SERIES RECORD "QI" on ABC1 - with 13 episodes/wk, would occupy over ¼ of available schedules!).
Also you cannot pad these recordings - adding a few minutes before/ after in case program starts early/ ends late. Changed recording time may conflict with other recording schedules meaning program may not record (check by EPG Search). Takes some getting used to to ensure consistent recordings.
Setting up standard weekly etc TIMERS may be preferable & more predictable.
EPG Search:
Searches for all programs by title within 7 day EPG, on all channels. Shows & allows setup of recording schedule, and if there are conflicts between SERIES RECORD & recordings, to set Priority.
Scheduled Recordings from EPG:
Settings for recording Once, Daily, Weekly, Weekday/ Weekend.
You can pad scheduled EPG recording times by up to only 10 minutes, in case program airs early/late.
(The older 1000 model can pad up to many hours - e.g. to record multiple consecutive shows on 1 recording, and the recording date can be changed to skip that particular recording. You can manually set up recordings to achieve this on this PVR, but then lacks program name, which you can rename. An advantage if you are running out of schedule recording slots.)
Time Shift:
Up to 2 hours, which is adequate. Can set to always be on, so can pause/rewind live programs when you wish. (1000 model can be set to almost limitless Time Shift. Mine is set to 4 hours.)
Editing Recordings:
Editing would suggest removing unwanted sections, but this PVR simply marks sections of the recording for viewing, skipping the unwanted. The file remains the same size, and copying the file to another device leaves the original unedited recording.
Settings:
MENU-PVR Settings: (handy when setting up)
Set Time Shift length (30-120 min) + Time Shift Function (Disable / Enable)
Playback Start Position (Beginning of program / Continuing from where you were watching) Continuing is handy.
Auto Play Next Program (Disable - stops playing at end at end of recording / Enable to watch recording then next recording )
MENU-Settings:
Audio&Video Output Settings
(set to suit your TV etc)
Time (by State & Daylight Saving - otherwise EPG & recording time will be incorrect)
Channel List (press OK during live TV):
Can delete unwanted channels (which the 1000 model annoying could not).
Can set up 1 set of Favourite channels
External USB Storage:
2 USB (1 front, 1 rear) capable of accessing larger HDD (tried with 3TB) formatted as NTFS or FAT32. So quite useful, as I found on 1000 model.
Copying is painfully slow. On 1000 model, crashes occurred when storage for recordings was set to a USB device (MENU-PVR-PVR Setting-Recording Storage) - don't do it!
USB drives less than 16GB can't be formatted on PVR.
WARNING: If PVR freezes (too high load on processor like copying too much or Copying + Recording) while writing to external HDD, HDD may be corrupted when you are forced to unplug PVR from power! (Have had Seagate HDD totally corrupted twice with 1000 model - files cannot be recovered due to storage method). Best not to copy too much at time to HDD!
Networking: (Not assessed yet)
Via Ethernet cable. Can access recordings, photos, music on PC, and transfer to PC from PVR. Access is typically MUCH faster than to USB storage. But requires files to be in set folder, which may be unsuitable.
Media Player (Not assessed yet)
Photo & Music Players have been added . Playing MP4 files is not great.
Annoying aspects...
OSD can't be hidden when using Pause
Pausing live program, or recording leaves an information box on screen - there is no way to remove it. Pausing a recording is something I regularly do, to view details. The PAUSE bar includes the EDITING tools, making it larger than normal. As the on-screen-display covers nearly 20% of the screen, at the bottom, subtitles and information bars broadcast with the program can't be seen! You can only increase the Transparency, meaning you can see through the OSD (MENU-Settings-PVR Setting 1-60%). However, setting a high level of Transparency makes using any OSD difficult.
Slow boot time
It takes about 35 seconds to.power up from Standby to fully operational. While that is marginally faster than the older 1000 model, it is slow.
Slow navigation within EPG, Timer & Media Browser etc
There are no P+/P- (Page up/down) buttons as on 1000 model. Moving up/down a list to select between possibly hundreds of programs (recordings) is SO slow - moving 1 at a time instead of a page at a time. (Strangely the P+/P- can still be found in the onscreen keyboard when you Rename recordings or do an EPG Search. There it performs a keyboard shift function.)
Slow navigation within Recordings & Time Shift TV
FF/REW speed is a maximum of 32X, against 64X on 1000 model.
There is a very handy undocumented feature of FF/REW by holding down the right/left arrows - located around the circular OK button (while watching your time position on the progress bar). Handy for moving quickly to position in program or skipping ads. (I found this on the earlier 500 & 1000 models.) However it is SO much slower to FF/REW on this model.
Bright Standby light
As in the older model, the very bright blue light can be annoying, but easily fixed with a small piece of black electrical tape or similar.
PVRs take time to discover their flaws & features, so I'll keep exploring ;-)
Aug 10, 2013 • Cell Phones
1helpful
Can't start HD, I can hear only biping sound
a biping sound is usually indicative of either a dead drive, or not enough power on the USB bus (for unpowered external drives).
If the drive will take an external power supply, but is not connected to one, try connecting a power supply to it.
If the drive is out of warranty, try removing it from the external enclosure and hook it up internally to the PC. Sometimes the enclosure interface fails. If the drive makes the same noise inside the PC, it's likely dead.
It says i need to format the disk and I have valuable info on there that I cannot afford to lose
Formatting will eease all files on the exteranl hard drive, assuming it is external and probably a USB 2.0 connection. Please follow the steps to access data that is on your drive.
First, does it appear in the windows on My Compter, there would be your primary drive as C, then the external may be D, DVD ro CD drives may be, E or F.
If not, right click on my computer, and click on the popup box on manage.
This will open a window with the left side listings, click on disk management.
Your drives should show up propabaly starting with your C drive, is your external drive in the list? If it is, what is the letter assigned my windows, if no letter, you will see on the right side " more actions", click on it and then click on "all Task". Make sure if your drive show up you can clcik on explore and then veiw what is on your external drive.
You should selct all, copy and paste the contents of the drive to a file folder, labeled external drive files and verify they are moved to the folder before you format the external drive.
Good Luck
I recently purchased a Verbatim USB 2.0 1-TB storage External Hard Drive. I have a Mac with OSX 10.5.8. I properly connected the hard drive to my computer and an appropriate screen display icon which I...
The NERO software is most-commonly used to write to CD/DVD/BluRay recordable media.
With Mac OS, just "drag-and-drop" your files and folders onto the icon for the drive, to "copy" the files.
External hardrive not recognized
Try a different cable between the computer and the drive.
Disassemble the casing, and remove the "internal" disk-drive.
If the USB-to-disk-drive adapter has "died", it's possible that the
disk-drive itself is intact, and your data will be intact.
Connect the "internal" disk-drive as a "slave" drive in a desktop computer, and see if it can be detected.
If it's dead, and it's still under warranty, then exercise the warranty.
OS whont start whit WD 1 TB external drive.
You need to set your boot sequence in the BIOS so that it does not include external drives. Basically your computer is trying to load Windows from the external drive instead of its own internal one.
Your motherboard manual is going to help, if you can't manage it by yourself give me a link to your manual or tell me the model of your motherboard and i will show you what you need to change.
Grand Canyon Tech
Grand Canyon Tech
