2002 Saturn VUE Logo
A
Anonymous Posted on Sep 24, 2014
My Saturn vue 2002 does not want to work because it just starts but, than it stops like working than I just wait 10 min and it starts to work but I don't know whats going on?
It starts the it like turns off then in 10 min it starts back on
Ian Francisco
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Sep 24, 2014
Ian Francisco
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
2669
Points
57
It's the security system. You'll notice when you try and start it, if the problem is happening, the security light on the dash will be blinking. The remote won't reset the security system. You have to wait the full ten minutes and it can be very annoying. I think it has something to do with the driver's seatbelt switch. There is a double wire under the seat that goes to the seat belt buckle. Mine was cut and taped back together. I think the switch in the buckle gets dirty. Try squirting some WD-40 in the buckle. Also try to not be in too much of a hurry when you jump in and start it because that's when it happens, then you're gonna be ten minutes late anyway. I just get in mine, sit down, and wait a second before I try to start it. Haven't had the problem for some time now.
5 Related Answers
A
Anonymous
  • Posted on Jun 28, 2008
SOURCE: spark plugs on 2002 Saturn vue
just completed a plug removal and install on my '02 awd v6. if you have the time and patience it's straight forward; common sense was most helpful. to gain access to the plugs, both fore and aft, you must remove, in short, everything near to, associated with, the air intake system. common tools plus a 1/4 socket, with 8 inch extension to hold a #10 star bit. these star bolts are under the rectangular plastic plate atop the intake. once you have those out, disconnect all the wiring, carefully. lift the intake out, look for plug covers, fore and aft, ignition assembly lays atop each row of three plugs. with the hands of a surgeon, remove the ignition assembly, and by golly ye shall see your reward. easy from then on.
replaced my plugs with the iridium 'honeys'; marked improvement in starting, acceleration, smoothnes, noise, and gas mileage to the value of + 3.0%. changed out the oil with mobile1 extended performance, changed transmission fluid. took a shower. time involved, 7.0 hrs. dealer be damned,,priceless!
Ronnie Wilson
  • 1596 Answers
  • Posted on Jan 24, 2009
SOURCE: fuel gauge
The fuel tank has 2 different fuel level senders(floats) It needs both of them. You have to drop the tank, and pull the pumps.
Anonymous
  • Posted on Mar 05, 2009
SOURCE: 2002 Saturn Vue V6 Loss of Power
Yup. The throttle body connectors have a history of failing on these cars. Replace the throttle body and the wire connectors that go to it, and you're back in business. Not terribly difficult and you can get the parts from any dealer. Saturn actually has a bulletin out on this problem but they won't cover it unless you're under warranty - no recall for this.
Anonymous
  • 299 Answers
  • Posted on Jun 17, 2009
SOURCE: o3 saturn vue power steering works when it wants!!!
Needs new electric collumn.
Anonymous
  • 10319 Answers
  • Posted on May 15, 2010
SOURCE: 2002 saturn vue, manual shifting problems
You have a slave cylinder for this trans. Pump the clutch pedal 25 times with the engine OFF. Then start it and try shifting it into each gear while parked. If this make it work your slave cylinder needs to be replaced
2answers
My vue is over accelerating as soon as i start it. changed the tps and it still happens.
2002 3.0 AWD...SES Light and won't accelerate - SaturnFans.com Forums
www.saturnfans.com > ... > Models > Saturn Vue > Vue Tech
Mar 10, 2009 - 4 posts - ā€Ž2 authors SES Light and won't accelerate Vue Tech. ... As in DRIVE it will not over rev when you push the pedal to the floor. ... Does any one have any ideas where I should start? ....2004vue, Vue General, 14, 07-16-2004 12:57 PM ... 99 SL1 Won't accelerate
Nov 25, 2013
slow accelerate 1st gear
Aug 27, 2012
shaking during acceleration - what is it???
May 9, 2010
If You Are Having Hesitation Problems on Acceleration ...
Apr 25, 2004
More results from www.saturnfans.com
200 Complaints: 2003 Saturn Vue Power Train: Automatic ...
www.carcomplaints.com/Saturn/Vue/.../power_train-automatic_transmiss...
The 2003 Saturn Vue has 200 NHTSA complaints for the power train:automatic ... At 76,000 miles when accelerating to get on highway, the RPM's were roaring .... Car junked, waste of over $20,000, I can't believe there has been no recall. ... we think this problem makes this model a lemon from the beginning. ... Nov 192004 ...
Where is the transmission control module in a 2002 Saturn vue awd
Where To Find The TCM Module 3 0 Litre Saturn Vue ...
? 1:00
https://www.youtube.com/watch?v=2DehorzZT5E
Dec 10, 2013 - Uploaded by Thinking out side box
TCM = Transmission Control Module Can Be Found Right next To The ... Saturn vue 2002 3.0 v-6 Thermostat removal, Intake, valve cover ...
Shop for transmission control mod... on Google
1helpful
My odometer on my 2002 Saturn Vue just stopped working. I have attemped to find replacement ,but unable to find a new odometer for the car. Where can I find a replacement.
2 Questions:
Do you mean the miles counter or the speed needle ?
is the Engine light on?
and also where are you located?
I am in Los Angeles and it would be possible to locate one for you.
1helpful
Saturn vue 2002 starts when it wants to
sounds like a bad crank sensor,nothing you did wrong,just a common 3.0 v6 saturn issue,its located on the front of the engine block under the car by the oil filter housing,,,like $115 for the sensor
My 2003 saturn vue battery died and now it will turn over but not getting gas.. Dome lights or sucurity wont work
you may have to replace body control module, I had to tow my 2002 saturn vue v6 about two years ago to the dealer approx $500.
2answers
2003 saturn vue fuel gauge stopped working
can you tell me why does the gas thing does not go up when i fill up
2helpful
20002 Saturn SL, replaced steering column. How do I...
Try to start the leve key on for 10 min, turn off (wait 10 sec) then try to start again and leve on for 10 min again, turn off and try again wait 10 min, turn off for 30 sec and then start engine.
Fuel gauge
Top Saturn Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Saturn Expert? Answer questions, earn points and help others
