Cars & Trucks Logo
Kennith Murray Posted on Sep 14, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to adjust the valves on a Kohler command 13 engine on a Husqvarna
Spitting spiders for about two to three seconds like it's going to crank up and then just shuts off and then the crank turns backwards
Sam
Level 3:
  • Master 3,247 Answers
  • Posted on Sep 14, 2014
Sam
Master
Level 3:
Answers
3247
Questions
0
Helped
1306452
Points
10378
Husqvarna with 25 horse kohler engine, will not crank with the key. New battery, new solenoid and power on all 3 legs of solenoid with ignition in on position. It will start with a remote start
You have the wire from the starter switch that activates the solenoid on the wrong side of the solenoid. Switch the 2 wires side for side.
2answers
How do you adjust idle speed 1991 johnson 100 hp
not important, what's important is that they are absolutely clean, including the four brass high speed jets located in the bottom center portion of the carburetor.
That model engine's carburetors has fixed jets, BUT if the slow speed jets are adjustable, earlier model carburetors have been installed. If so...................
The four adjustable needle valves control the flow of fuel in relation to the set air flow, adjusted as follows (if needed).
(Dual Carb V/4 With 4 (2 each carb) Slow Speed Adjustable N/Valves)
(J. Reeves)
The adjustment procedure of the carburetor slow speed needle valves follows. NOTE... if the needle valves turn too freely, replace the nylon bearing retainer (the nylon item at the front of the carb that the needle valve goes through first) with the newer type RED retainer #315232. If your engine has that weird linkage that connects all four of those needle valves, the newer RED retainers will enable you to discard that linkage. The RED retainers make it impossible for the needle valves to vibrate out of adjustment.
(Carburetor Adjustment - 2 Slow Speed Adjustable Needle Valves, each carburetor)
Initial setting is: All (4) Slow speed valves = seat gently, then open 1-1/2 turns.
Facing the carburetors, start with the top left needle valve, then the top right valve, then the bottom let valve, then the bottom right valve. It may be necessary to redo these steps to get the adjustments ideally set
Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.
Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
Do not attempt to gradually adjust all four of the valves at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve.
When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
My 2000 jimmy takes about 10 to 20 engine cranks in the morning when its cold out.when it starts its good the rest of the day. but its getting worse the amount of cranking the engine over in the morn
I'd use a fuel pressure gage, check fuel pressure, key on, engine off, first thing in the morning, 60--66 psi, spider fuel system. If you have the spider fuel stem, that system is noted for problems.
There is a service bulletin for cold start-up problems, caused by fuel poppet valves sticking. Once you get it started, it runs fine the rest of the day. The poppet cleaning procedure shows to be a shop procedure.
How do you load the cam actuator after changing the head gasket on a 2006 Hummer H3?
two ways: cranking the engine by turning the crank pulley bolt. Best done with valve cover off to verify full engine oil prime. The other economical way is by disabling the ignition and fuel pump (fuse removal) and cranking engine for 5 seconds, three times each.
2answers
Have a chev blazer 4.3 THROTTLE BODY V6 ,HAVE 2 SPRAY STARTING FLUID IN BREATHER & starts & runs all day,no problems . Shut off & in 5 min wont start again, unless u spray it 4 2 seconds again? Whats...
Maybe a problem in the fuel pump circuit. Check fuel pressure with engine off, and key turned to on, not start. If no pressure, diagnose the pump circuit at the fuel pump relay. One terminal for the relay would be the power feed for the pump. The engine computer signals the relay on for 2 seconds with key on to prime the system, also signals during engine cranking.
2helpful
I need to adjust the valves
12th inlet and 14 exhaust ,4cyl engine all valves add to 9 ,,example--- no1 down adjust no8 ----no2 down adjust no7 all values add to 9 simple if you take your time to count the valve thats down subtract from 9 and then adjust that number ,this system works on all engine regardless of what the haynes book says ,6 cyl engine then its 13 ,and a 8 cyl engine then 17 ,in cases of 16 valves in a 4 cyl engine then its still the same as two valves work as one ,simple
Replaced fuel pump spider still no gas at poppits
4.3 L engine crank position sensor is located on passenger side bottom of timing cover. plug should be around the front of the intake manifold.
2answers
Rebuilt engine valves not adjusted.1970,s model 350 chevy i need to know the proper way to adjust before start up
you need feeler guage, youl need find the valve clearence to set it and adjust each one by using the rule of 9
95 gmc 5.7 spitting back and losing power after warmiing up
Have you checked fuel pressure? You said TBI so it needs to be around 11-12-13 psi
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
