Fuel pump relay is behind the ash tray and behind the fuse block. Check for 12V DC at the relay fuse block. Swap out the fuel pump relay. I always carry a spare because it can leave you stuck. Fusible link problems would knock out our entire 12v system.
Fusible links are either by the battery or down by the starter. But if everything else is working, this is not the problem You have a bad connection(pull the fuse and reinsert it or a broken wire). Most wires break close the the plugs.
