Northern Tool + Equipmentour Authorized Service Centers located throughout the United States can give you quick service. ... HOW TO GET SERVICE ..... Exploded View Drawing JDP-15M/MF . ... If you are not familiar with the proper and safe operation of a drill press, ...
University of Notre DameCompletely read the safety and maintenance instructions before operating or servicing the machine. To obtain maximum life and efficiency from your JET Drill Press, and to aid in ... Authorized Repair Stations located throughout the United States can give you quick ...... A spindle speed and pulley/belt arrangement chart.
New trigger switch. It's sticking. Can of electrical cleaner may take care of problem. Slide between forward and reverse may be in question. Had that problem also and a generous cleaning with a spray took care of.
Before you look for a replacement of switch try first to checked the connections of switch if it is OK,then try to cleaned the contact with it.,If you are know how to used a tester try to checked the continuity of the switch, by placing the test probe of the tester to the 2 wire of the switch then from the tester select sound continuity,(one test probe to one wire) it should hear a sound from the tester,it means the the switch is good. Hope this simple solution could help to solve your problem. Don' t forget to rate me up sir/madam.Thanks.
You can download the instruction manual from Screwfix http://www.screwfix.com/prods/59109/Power-Tools/Cordless-Drills/Ryobi-CDI-1201-12V-Combi-Drill?cm_re=SEARCHPROMO-_-RYOBI%2012V%20DRILL-_-59109
Or try http://powertool.manualsonline.com/manuals/mfg/ryobi/ryobi_cordless_drill_product_list.html if it's a different model - however, most models are the same
