Maytag 30" Built-In Single Electric Wall Oven - Black Logo
A
Anonymous Posted on Sep 08, 2014
Maytag model number mew6527dds when you turn to bake the broiler comes on
Chris Huff
Level 3:
Top Expert:
  • Maytag Master 6,289 Answers
  • Posted on Oct 04, 2018
Chris Huff
Maytag Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2020419
Points
74913
Could be that the bake element is bad and needs replacing.
Richard C Cohen
Level 2:
Legend:
An expert who has written 200 answers of more than 400 characters.
  • Maytag Expert 318 Answers
  • Posted on Nov 07, 2015
Richard C Cohen
Maytag Expert
Level 2:
Legend:
Answers
318
Questions
0
Helped
120812
Points
917
The oven control board is defective--most likely the electronic control chips have been damaged and are causing a crossing of the functions.
1 Related Answer
Anonymous
  • Posted on Jul 11, 2010
SOURCE: oven won't light.
Localwonder gave a more comprehensive answer, but I wanted to share my recent related experience too:
Same model: MGR5750BDW
Oven was not heating up, or would sometimes and not others. Broiler worked fine. The nice thing is that the broiler igniter and the oven igniter are the same part. So I swapped them until I could get a replacement part.
Before I did anything, I turned off the gas!
To take out the broiler igniter: there's one screw right near the front of the oven that holds the burner assembly in place. Remove that, gently pull the assembly off the gas nozzle off to the left. Then where the wires from the igniter go into the back wall, remove the screw that holds the little door, remove that little door, and then gently pull the wires through until the connector comes through the opening. I also found you can go behind the stove, remove the back panel (which is easy) and see the igniter's connector.
The oven one: remove the floor of the oven by lifting it at the back, and then lift it out towards the back of the oven. Then you can see the igniter at the back of the floor of the oven. remove the two mounting screws, and then gently pull the wires until the connector comes through the insulation.
The bad igniter looked like it had burned down to bare metal in a big patch...not sure if that's the actual problem, but in any event, I installed the good igniter in the bottom (gently pushing the reconnected connector through the insulation, and feeding as much of the wires down in there as well), and the bad igniter in the broiler position (since that was the easiest one to access and replace, it'll be easy enough to replace when I get the parts). Tested, and everything worked great. And I could watch the bad igniter light up, and never light, confirming that it was the igniter itself that was the problem.
The best part, for this stove anyway, -- the ONLY tool needed was a #2 phillips screwdriver. Really. All told, maybe an hour of work, nothing intense. And free -- so if they both worked, it would have spared me ordering a part that didn't need to be replaced!
1helpful
I have a GE 24 inch wall oven model number JRS04B0W5BB that when bake is selected the broiler element comes on and then after awhile it looses temp and does not cook anything.
Ovens often use broiler element to preheat, then shut off when set temp is reached. Check fuses for and bake element itself.
Dec 01, 2014 • Ovens
Maytag double electric oven. we turn on to bake and would switch to broil then will turn off.
Assuming this is on a gas range, the bake burner ( under the oven floor) and the broil burner ( at the top of the oven) have electric igniters . When switching from bake to broil the broiler goes off due to a defective or broken broil igniter. cheap part to replace ( +-$40.00)
1helpful
Neither oven or broiler work. Upper elements work well. Why is the bake light flashing / blinking?
if it is not coming on then you may have the same problem again with the ignitor.
May 04, 2014 • Ovens
Bake and light buttons no longer working
REPLACE THE CONTROL PANEL...WORKED FOR OUR OVEN. SIMPLE FIX.
2answers
MEW6527DDS oven: some keypad buttons have stopped
(I'm providing a late, modern response for people like me who land here in 2022+)
I had the same problem. Gradually it got worse until only Bake ' Cancel work. Sometimes the problem is due to bad ribbon cable connections; sadly, with this oven, the issue is the membrane buttons having failed. It's frustrating, because this has happened with every version of this model that I have seen. Add to this that the membrane buttons are behind a sealed panel that you can't access without breaking it, and you'll quickly learn that you need to buy the replacement part. 5765M483-60 is the matching control unit, but make sure with the vendor that it is the right size for your unit first; it's expensive. It's also now out of stock and is a 2-3 month special order at most vendors. The replacement is tedious, but simple and approachable for a first time DIY'er. At this point, I'd rather buy a new replacement oven instead, but finding 27" models is difficult as most are 30" now, which won't fit my cabinetry - thus I bit the bullet and bought the replacement control unit. Oven came with the house on purchase; former owner told me she had already done the same repair once before; so that means this problem will keep recurring.
Maytag single electric built in with a display saying sab bath
It is in Sabbath mode, used for Jewish holidays. Anyway, hold the cancel button for 3-5 seconds and it should revert back to normal operating mode. It will still bake in Sabbath mode but will not display anything due to the laws regarding observation of the Sabbath
1helpful
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Maytag gas oven mgr5770abb Does not light when I try to use oven. Broiler works fine. When I try to turn on the oven, the broiler igniter does not glow. If the bottom igniter was bad, wouldn't the top one...
first I would check to see if you have power (120v) at the bake igniter..when you set in to bake...use a multmeter..(when you turn on the oven to bake only the bottom igniter will come )
good luck be safe
let me know if I can help
Overn will not work properly
sounds like you have a bad oven ignitor, very common problem with alkl gas ranges, easily repaired by you a few screws and a wire harness part number 12400035
Apr 05, 2008 • Ovens
Top Maytag Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
