the wiring from the wheel controls may have come loose at a connector so i'd try making sure all connetors are pushed home , even behind radio , have you had any work done recently to the vehicle ?
there is what is called a clock switch located under the steering wheel that must have went kaput. it is what transfers the signal to the steering column.
Is the vehicle fitted with the standard stereo fitted by the manufacturer? If not, then there is a strong chance that these controls are not compatible.
i also have a 99v70. As i was driving the car home 2 days ago in cruise control. Suddenly the speedo dropped to '0'. The cruise control quit and the abs, upshift arrow, and check engine light came on. The solutions is the 'abs control unit' From Volvo; 870.00 from Advance; 256.00 w/ core exchange. Its fixed all those dash issues.good luck
Need more data...if you are saying the cruise control and radio don't work, then its probably 2 separate issues. Cruise control shares fuses with the instrument panel, if your gauges work then its not the fuse...if its a 5 speed could be a switch not working that operates when the clutch is pushed in (if you push the clutch, the cruise will disengage to keep engine from revving). Radio shares fuses with headlite lift motors...if your headlights pop up then its not the fuse, maybe just a bad radio...blueamber...I've owned 6 of the capris
could be a bad clocksping the airbag is on it to but one of the thin film "wires" that are glued to it may have cracked.all the switches are on one "wire" the resistance of each switch is how the body control computer knows what button is pushed. i broke one of those clocksprings accidently when i worked at volvo so thats how i know those things are/were 1400.00$ i would take it to the dealer to have them diagnose and repair. the clock spring breaks real easy when you take off the steering wheel.
Check the brake switch below the brake pedal. It may think the brake is being pressed if that switch is not working properly. Also check for vacuum hose leak or damage in the same area.
How about the turn signals, are they working? If not, then pull the fuse for the Steering Wheel Module (SWM) to reset the module. There is software upgrade from Volvo to prevent this in the future!
