NO NO NO NO NO NO
--- No--- LEAK SEALER goes into-- ANYTHING-- EVER--
Leak sealer RUINS things & you CAN NOT GET IT OUT
It will clog the A/C orifice,expansion valves,the coils,gum up the
compressor
In the cooling system it will ruin all of it,thermostat,heater core,
radiator
I would say look at & read but NEVER buy ANY Doctor Do
Goods off an auto parts store shelf ever
The ONLY thing you buy in there is Permatex Anti-Seize,Thread-Locker & Gasket Sealer & brake tubing
I don't buy parts there anymore
If you have ANY Vehicle problems
You find them & do only the proper repairs
When you spend 40 to 60,000 dollars, you do not spend
$8.00 on a quick fix, that is just a cash cow for the marketing
& supply chain & useless for your vehicles
SOURCE: 2001 Ford F250 7,3l diesel 4 x 4 automatic.The AC
That would probably wipe out your Drier and the soap may corrode the moving parts in the compressor.
There is a testing kit at Autozone and Advance autoparts which uses a dedicated can of dye marker. But this kit is an UV kit which has a UV source penlight, yellow plastic goggles, and a small can good for 4 to 5 tests.
When you add the UV marker, as with any others, make sure your compressor clutch is working and run the engine to circulate the stuff.
When you put on the yellow glasses, and use the UV pen, Stevie Wonder could see the leak. Now after all of this, if no underhood leak can be found, use the UV tester at the A/C drain from the Firewall. It is possible the leak is inside the cabin and the water from the ductwork drain will let the UV marker escape.
I would like to know if you bought this product and if you found the leak. Remember too, that the sniffer detector still works and may be the final way to fix you up.
SOURCE: dodge caravan 1996 have a leak on ac compressor
depends how bad is the leak they do make seals but after labor and they usually last 1 to 2 yrs only ull wish u bought a new one u can try remanufactured dont rec
