Only turn to the right
Your spindle may be seized. try turning the side by hand. Try moving it back and forth. If there is movement then your bearing in your spindle is bad. I f no movement than check under your deck to make sure nothing is stuck holding the blade from turning. You will probably have to replace your belt as well
