Home | A4tech | PK5 Personal Web Camera | Microphone is not wor...
A4tech PK5 Personal Web Camera
Problem for A4tech PK5 Personal Web Camera
Microphone is not working
By lana_srcence on Jun 30, 2009
Cd instalerr is alredy instaled but the microphone is not eorking!
Solution #1
posted on Aug 29, 2009
Not Rated)
FYmickydee
Rank: Guru  Computer Accessories  Expert
Rating: 88%, 165 votes
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;} Audio set-up Visa x Yahoo Messenger
TEST SPEAKERS
Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab. Set required mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK Click "Levels" tab and set slider to 80% ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
CONFIGURE TO MESSENGER Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK Click ( > ) Messenger > Preferences > Calling and Audio Set mic and speakers to show Default equipment Run call up assistant to test audio equipment > Apply > OK
Was this helpful?
Yes
No
Solution #2
posted on Aug 28, 2009
Not Rated)
yooperbud
Rank: Wiz  Computer Accessories  Expert
Rating: 82%, 1912 votes
Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone or Headset.
Click OK and it should work.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your Computer does not set it up to broadcast on messengers or Skype. Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
2. Then click on the Video Settings.
3. The camera if Installed Properly will come up and show a video picture.
4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able tosee and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html) set it up as follows:
1. Go to Messenger at the top left and click on it.
2. Next go down to Preferences and click on it.
3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
3. Next go to the Menu Bar on right side, click on “ “Action.”
4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger
Go to this site http://dashboard.aim.com/aim and Launch AIM AOL Messenger.
1. On the VIM sign-in window click on Edit.
2. Then click on Settings Enhanced IM.
3. Next click on Enhanced IM.
4. Then click on Audio Video.
5. The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings,
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
Notes:
· The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
· Images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Was this helpful?
Yes
No
Popular Solutions for A4tech PK5 Personal Web Camera
Questions and Unsolved Problems for A4tech PK5 Personal Web Camera
Do you recommend A4tech PK5 Personal Web Camera?
Answer
Answer
how do i shut off night vision on a a4tech PK-7MAR
Answer
i recently bought a computer and i purchase a a4tech camera and my people in the other side canot... (More)
Answer
Help, anyone please, what will I do with A4tech PK-730 Web Cam if it became blurred?
Answer
I suspect somebody used the pc with a webcam in our company, when I opened the A4tehc video camera I... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For A4tech PK5 Personal Web Camera:
Top Web Camera Experts
Rank: Guru Guru
Solutions: 14110
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Web Camera Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
