Hi there.......your problem can occur when the sump of your apliance becomes flodded....this activates the anti flood switch which causes the drain pump to run....soloution is to dry out the sump or remove machine from its location...tilt it back letting excess water flow from the sump..check that all fixing screws in cabinet are secure including the air vent (mid way u the left/rt hand side of inner cabinet...
test appliance again if problem persists you will need to change the water flow meter
regards Sir Galahad
Brilliant! I had the same problem. Because of your solution, I opened up my machine a third time and looked for the air vent.
I didn't find it, but had a good look round and discovered a tube had come loose, which must have been a draining tube going to the pump. It was draining the water into the sump as soon as it started running.
It was quite greasy, due to some gunge so I cleaned it out, reattached it, screwed the base back on and plumbed it it again.
Bingo! Thanks.
SOURCE: I have a Beko DE 2541F Slimline Dishwasher and it
If there are no problems of drain valve stuck, then the problem with the micro controller board.
When the water is full in the tank, the wash cycle will start with the spray arm in action. Lastly block the drain hose and see. Here water full will be detected & the machine will start if the level sensor is OK .
If m/c works here, you have to check the Solinoid valve of the drain.
Otherwise the micro controller.
For this pl take the help of the service provider as lot of programming versions are there. Some may suit or may not. If we try the will not accept after selling the board to u.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
