Kodak EasyShare C613 Digital Camera Logo
Posted on Jun 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Camera was left in rain.
The camera was left in rain. I keep getting lens error codes of 20e,1,0,0. The camera has been in the house for a while. The lens does not extend. Any help?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 248 Answers
  • Posted on Jul 06, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
248
Questions
0
Helped
59946
Points
539
This seems to happen when something (water, sand, dust)
gets trapped in the lens mechanism.
The recommended methods include taping on the
bottom of the camera,rapping it on a table,
and pressing hard on the lens.
If the lens moves when you turn the camera on, try keeping your hand on it so that
it's forced back into the camera body.
A can of compressed air squirted around the
lens is also a possible fix...
but be super careful with that stuff,
a good hard blow of breath might be safer.
I'm not recommending that you do crazy stuff
to your camera, but if you're careful you may
be able to get it working again without having
to get it serviced.
My Kodak easy-share len is stuck. what do this Len error 20e 1,0,0 means?
There are some steps which can be followed which may resolve this problem which as follows,
1: Switch on the camera while you hold the shutter button and connect it to the AC adapter or to the USB cable at the same time.
2: Now by default the lens should get properly aligned if not try to twist them slightly by holding down the camera lens with soft hands.
3: Just push and pull the lens slightly as it extends automatically.
4: Now when the lens is in the hard surface power on your camera.
5: Try to hit the camera softly beside the lens which might solve the issue.
You can try to format the memory card completely and then reinsert to your camera which might be the issue at times.
1helpful
How to fix lens error: 20e,1,0,0 from kodak c613
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
1helpful
Lens will not retract lens error 20e,1,0,0
Put in fresh batteries in your camera and try to power on. If this didn't work, do this little trick:
1. Hold the camera on your right hand with the lens facing the ground.
2. As you press the power on button, tap or hit the camera's base to your left palm. Do this several times.
Chances are, there could be a sand or granule of dust that got stuck on the sides of the lens, preventing it to retract properly.
3helpful
2answers
Kodak easyshare c713 showing lens error 221,0,0,0. what does this mean.
KODAK C713 LENS ERROE 20E 1,0,0?
IT DID NOT RESOLVE AFTER PUTTING NEW FULL CHARGE (AA) SIZE BATTERY EVEN , WHEN I TURN ON CAM IT SHOWS ERROR 20E 1,0,0 AND SHUT DWON.
2helpful
Lens error 20e,1,0,0
My kodak easy share c813 is being wonkey.
it appears that some small objects could have lodged themselves into the lens gear/guide.
take the camera with the right hand and hit your left hand with it (softly).
Do this from all sides, except the front.
You might be lucky.
Kodak easyshare c613
you need to clean your lens with a tissue sort of cloth, DO NOT GET IT WET! that will ruin your camera.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
