1996 Volkswagen GTI Logo
Anonymous Posted on Jun 29, 2009
1996 vw mkIII gti aba 2.0 ac not cooling.
I just charged it up today but no progress. when i switch to heat then back to cold it cools for a second then goes warm again. could this be my heater core?
Anonymous
Level 2:
  • Expert 218 Answers
  • Posted on Jun 29, 2009
Anonymous
Expert
Level 2:
Answers
218
Questions
Helped
134211
Points
660
Hey there..my name is Keith..and i can answer your heater core question..NO..its not your heater core...it sounds like the A/C -Heat control module in the dash is the problem..but that just a guess..but No..it has nothing to do with your heater core..if ya have other or need assistance..write me back...and i hope this has helped
I have a vw polo 2002,when stuck in traffic or after long drive,the ar goes off
does the temp gauge reach the red area? check eng coolant .Over heating could cause eng to cut out so as not to cause more damage check the cooling system.When travelling slowly or at stand still turn heater to max heat and max speed this will cool eng but is only a temporary solution
Broken wires ac wont cool
I have discussed this with you and have advised you that you need to see dealer assistance on this.
What is the warning light on 2005 vw gti
Hello! A thermometer light with two wavy lines underneath the thermometer indicates a problem with the VW's cooling system...When the engine is cold; Check the coolant level in the radiator...If it is full and since the light goes out when the engine reaches normal operating temperature the Low Coolant Level sensor is defective...But I suspect the level is low..
Guru...............saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
2answers
Volkswagen golf 2.0 tdi service manual
1993-2005 Volkswagen Jetta, Golf, GTI, Cabrio (A3-A4) Hatchback & Sedan Workshop Repair Service Manual - 350MB PDF
1993 2005 Volkswagen Jetta Golf GTI Cabrio A3 A4 Hatchback Sedan...
This is a COMPLETE Service and Repair Manual for your 1993 1994 1955 1996 1997 1998 1999 2000 2001 2002 2003 2004 2005 VW Jetta, Golf, GTI, Cabrio (1.8L turbo, 1.9L TDI and PD diesel 2.0L gasoline, 2.8 LVR6) (A3, A4 Platform) Hatchback & Sedan. It covers every single detail. All models, and all engines are included.
This QUALITY manual is 100 percents COMPLETE and INTACT, no MISSING/CORRUPT pages/sections to freak you out! Detailed illustrations, exploded diagrams, drawings and photos guide you through every service repair procedure. This manual can be viewed on any computer, as well as zoomed and printed. All repair procedures are covered A-Z. This manual for VW Jetta, Golf, GTI, Cabrio makes any repair job easy to do with very easy to follow step-by-step instructions & pictures on all areas of repair.
Format: PDF
System: All Versions of Windows, Mac, iOS, BB, Android, etc..
Requirements: PDF Reader.
Printable: Yes
TABLE OF CONTENT (example)
GENERAL INFORMATION *
ENGINE *
engine mechanical
engine lubrication system
engine cooling system
engine control system
fuel system
exhaust system
TRANSMISSION/TRANSAXLE *
clutch
manual transaxle
automatic transaxle
DRIVELINE/AXLE *
front axle
rear axle
SUSPENSION *
front suspension
rear suspension
road wheels & tyres
BRAKES *
brake system
parking brake system
brake control system
STEERING *
power steering system
steering system
RESTRAINTS *
seat belts
supplemental restraint system (srs)
BODY *
body, lock & security system
glasses, window system & mirrors
roof
exterior & Interior
Instrumental panel
seat
AIR CONDITIONER *
air conditioner system
ELECTRICAL *
wiring diagrams
starting & charging system
lighting system
driver information system
wiper, washer & horn
body control system
lan system
audio visual, navigation & telephone system
auto cruise control system
power supply, ground & circuit elements
MAINTENANCE *
maintenance
INDEX *
alphabetical Index
2helpful
2002 Chevy Express 1500. A/C Full of freon, fan blows hot air and not cold at all. What can it be?
check all fuses first. does ac compressor come on? if not, unplug pressure switch in low pressure line near where you add freon and short across pigtail. comes on now and cools? replace switch. if not plug back in. apply manual voltage to ac compressor. comes on and cools? if not compressor or clutch is bad. if it does, check ac relay. that's about all you can do with limited tools in the driveway. if no progress has been made, time to take it to the pros.
2answers
My 2001 vw passat's a/c runs great for 15 mins at first start up of the car. After that - no cold air but the blower still blows. So if I dont have any further to go than 15 mins. Away im okay. What could...
Maybe there is a restriction where the r134a refrigerant flows. Or, the refrigerant is low on charge and shuts the compressor off due to this.
Good luck to you.
1helpful
Cooling fans do not run normally or in AC mode on 2003 VW GTI VR6
Check cooling fans not faulty - run freely.
Check the operation of the cooling fan control relay.
Replace relay, and observe if this fixes the problem.
Cooling fans not working
chech realey and water senso tem.
2answers
Temp control switch does not regulate temp i get heat on all settings except max ac
switch prolly not bad but you might wanna look into your heater control valve. valve not closing and letting the hot coolant fill your heat exchanger rather than recycling it back to the cooling system. The heat is over powering your a/c system and you're only getting a bit of cooling when you have the a/c on max. try it out
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
