If you are talking about the pilot flame being low it probably needs to be cleaned. you would need to shut off the gas to the fryer first. Then remove the gas tubing from the pilot assembly. inside of the pilot is a orifice. Looks like a tiny thimble. Remove it and clean the hole in the orifice. (Very Small hole) Reassemble and test.
There is an adjustment screw on the main gas valve, usually under a cover screw. It will be near where the small pipe that goes to the pilot light.
SOURCE: Pilot light won't stay lit
Wrong voltage thermocouple? must have 400mv, residential uses 25-40mv.
SOURCE: piot light will go out
its likley to be the thermal cut out playing up its not holding the gas on as its getting week a new one will sort this problem out first time
SOURCE: i have a pitco 35c
Check and clean the thermopile, it is the cylindrical piece of metal standing behind the pilot assembly.Try also to tighten its wiring connections to the gas valve and high limit.If it does not correct the problem, replace the thermopile.
SOURCE: I have a pitco frialator and the pilot will light
Check if the unit receives the right amount of fuel as stated on its nameplate, if it does, check all wires for loose connections, Milli volt wont pass on loose wiring. If this does not correct the problem, you have to replace the gas valve, the main valve coil may be shorted that's why the pilot is shut when main valve is energized.
