Cars & Trucks Logo
Posted on Jun 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Failure of soft top to function on z3
Failure of soft top to function pump is working but top refuses to go up or down
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 17, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
295
Points
Has the pump got enough oil
Colin Stickland
Level 3:
  • BMW Master 22,516 Answers
  • Posted on Jun 28, 2009
Colin Stickland
BMW Master
Level 3:
Answers
22516
Questions
Helped
6999593
Points
66324
In the boot onj the motor is a lever for the manual over ride ,has it been moved ??
4answers
I HAVE A 1995 M B 500 SL THE SWITCH INDICATOR FOR THE TOP & ROLL BAR STAY IN A BLINKING POSITION. THE TOP, POWER WINDOWS AND ROLL BAR WILL NOT FUNCTION AT ALL... THANK YOU
The control module has set a fault and it will have to be reset. They are sensitive to voltage & must have 12 volts to operate properly.
The windows and top will need to be resync. I cannot find any information regarding the diagnostic procedure for the roof .. it states there is a procedure to diagnose the fault with the number of flashes the switch makes .. a dealer may be your best option on this fault .. I hope this helps some.
Convertible cover for 98 bmw what is the part number or what is the proper name for the part that holds the covertible top down
How about "soft-top covering" 54318412054 in black.
Go to realoem.com and click :Enter"
Put in the info for your car (I guessed).
Find the section that has the part you want, "Folding Top Mounting Parts" for example.
http://www.realoem.com/bmw/showparts.do?model=CH33&mospid=48094&btnr=54_0194&hg=54&fg=10
5helpful
Z3 Convertible top - seems to be a common problem
In general, without any testing or diagnosis, you could be dealing with any of the following:
* Open relay - Located at the pump unit
* Close relay - Located at the pump unit
* End position micro-switch
* The operating switch itself
* An issue with the pump unit, but I doubt this, due to the intermittent nature. However, do check the hydraulic fluid level.
The windows do not have to be down for the system to run.
The brake pedal must be pressed while operating the switch. There is a switch at the pedal that signals the convertible top system, but if your brake lights are functioning, the brake switch will not be at fault.
The system is pretty simple and some quick electrical tests should locate the faulty item.
The Bentley repair manual for the Z3 has all of the electrical wiring diagrams, for use in the diagnostics. You can purchase this at Bavarian Autosport 800-535-2002.
Sep 02, 2009 • 2001 BMW Z3
2answers
1998 z3 alarm & immobiliser info
Ypu need reprogramming.
Aug 08, 2009 • 1999 BMW Z3
1helpful
My bmw z3 convertible top won't open
your need to have the motor and that circuit check and the modules on the vehicle the operate those functions
Jul 07, 2009 • 2001 BMW Z3
1helpful
Conv. top is not working, even though the motor seems to be fine
make sure the arm is connected from the conv. top motor to the convetible top. It is located behind the drivers seat by the door jam.
Jun 14, 2009 • 2000 BMW Z3
2helpful
2answers
2000 Z3 power top failure
i had the same problem and BMW told me it will cost 1200 AUD to fix. I fixed it for free. inside there is a tiny kill switch above the passanger side. it wont let the roof operate unless you lift the roof. that was the problem. it was faulty. I by passed it and it has been fine for 5 years. I can't find the switch to replace so when I watch and lift the roof like you normaly do when want to open it.
Oct 24, 2008 • 2001 BMW Z3
Z3 fuel gauge twitch
Do not top off tank when fueling. Had this problem and realized that it occured when I topped up after the pump shut off. No problem since. Feel that when topping up, you overfill the tank and fuel gets in the vent line and charcoal filter which somehow affects the fuel gauge. I have a 99 Z3 coupe.
Sep 09, 2008 • 2001 BMW Z3
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
